Hi!,
I need to keep track of the position of a blimp flying inside a closed environment, mounted on which there is an Arduino and some other sensors, but can't figure out a solution (I am fairly inexperienced with eletronics).
I have tried to use an accelerometer for this, since, according to some sites, it is possible, even though highly innacurate. I'm using an ADXL320 for the task, but the readings I get from it won't change when i move the it (it does change when I change the IC's inclination relative to the earth's surface, as expected). I think this is because the acceleration on a moving blimp is way too small.
I've also considered a GPS shield for the Arduino, but I don't think that would work since the blimp will be flying in a closed environment.
Also, the blimp is small, so there are severe weight restrictions on the components.
So, what are my options for keeping track of position of a flying object?
Thank you!
Thank you!
