Thermopile Switch
Radim S
I have following problem . The Thermopile probe ( 0.5V output @ 600 Deg C
with internal resistance 2 Ohms ) drives gas valve solenoid with very low
resistance ( approx. 0.023Ohm ) . Approximate holding current is 250mA .
So there is only about 5mV on solenoid . I need to cut off this circuit
with some kind of FEt , MOSFET or opto MOSFET . External circut to control
this switch can have common ground with above circuit. Cannot use relay -
external circuit does not have enought current to drive relay. I see
problem with relativly low switched voltage ( only 0.5V ) and low
resistance of fet needed .
Any ideas what could be good solution ?
Thanks Radim.
Jasen Betts
Mosfets are available with very low on resistances, eg IRF1324S
has 0.001 $5 ea at digi-key. you'll need 10VDC to switch it - is
that available?
MoiInAust
that available?
Can't believe how this ng has improved. Lots of good stuff and helpful
problem solving ideas. No flames, spam or interminable OT threads.
Radim S
that available?
I have only 2.5-3.0V from control circuit to drive gate of mosfet . This
voltage would be against common ground with Thermopile source . Will this
MOSFET or similar be able to switch only 0.5 0.7 V between S-D
junction ?
Thanks for your reply RADIM
Phil Allison
"Radim S"
** So you need a DC voltage booster to drive the gate of the MOSFET.
Try "sci .electronics design " - someone there may spoon feed you basic
design stuff.
..... Phil
Andrew McMeikan
Phil said:
"Radim S"
design stuff.
.... Phil
You could try a different way, if what you want to do is to shut off the valve, why
not steal enough current so it does not operate. Shunting current may increase your
options. How much drive current can your 3v signal supply?
cya, Andrew...
RAdim Stepanik
valve, why
increase your
cya, Andrew...
Thanks everybody for help.
But I thing I have found solution. Digi-key has Zetlex ZXMN2B03E6
N-channel MOSFET with very low VGS = 1.2V minimum
@ Rds=0.075Ohm. This should work OK with may requiremnts .
(http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=ZXMN2B03E6CT-ND).
Now I have 1 thermopile driving solenoid valve ( 0.5-0.7V @ 400-6000 Deg
C ) . Internal resistance is 2 Ohm so 0.075Ohm will still only marginally
effect current throught solenoid ( 0.023Ohm - need 250mA to hold ON valve
.. ) Additional part of this circuit is fed from 2 of the same ( but
separate from sol. valve ) thermopiles
in series . These two (2) ( 1.0 - 1.5V Dc out of them 4 Ohm internal res
.. ) thermopiles power flame sensing circuit ( Silicon labs C8051F931 MCU)
.. This MCu can run from 0.9 to 1.8 signle cell voltages and generates 3.3V
for output I/O . One of those I/O will drive gate of above MOSFET . I am
getting some parts tomorrow so I will let you know how it worked out .
Thanks for help again.
Radim S.
RAdim Stepanik
"RAdim Stepanik"
@ Rds=0.075Ohm.
** Reads as 1.5 volts GS when I looked.
** So what are you going to do with the other 2999 you don't need ?
..... Phil
Thanks Phill for 1.5V versus 1.2V Vgs minimum correction . I will have 3..3
V available so even 1.5V should work . At 3.3V Rds should be around
0.05 Ohm. These MOSFETS are available in single Qty - please read link
above . I will have 10 of them tomorrow on my desk , they shipped this
afternoon .
Regards Radim S.
P.S. Thanks to all for help and to Phill for his direction where to go for
"basic design" questions ....
Similar threads
Replies
5
Views
2K
clare at snyder.on.ca
Replies
58
Views
7K
John Larkin
Replies
2
Views
2K
Rene Tschaggelar
Replies
25
Views
8K
Rich Grise
