davenn
All the more reason to locate the watt-meter as close as possible to the antenna feed.
but not permanently
You should use a directional-coupler power meter like the legendary BIRD 43:
Yeah, I just might score one at the Dayton Hamvention this year if the price is right. I have this strange attraction for D'Arsonval meter movements, with or without a mirrored scale for parallax error prevention.even with their age, they are still one of the best units out there
RF ammeters like the ones @Y2KEDDIE has, or the simple vacuum thermocouple attached to a heater wire as in the image I posted, are functionally obsolete, replaced by better technology. However, the first principle of measuring RF power by measuring the amount of heat it produces is always valid. Only the methods have changed, not the fundamental principle. Thermocouples are still very much a part of RF power measurements, as are square-law diodes and thermistor sensors. Here is a very thorough discussion of the state-of-the-art in RF power measurement, published by Agilent (formerly Hewlett-Packard), a world-class leader in RF power measurement instrumentation.
The Bird Model 43 wattmeter is a tried-and-true in-line RF power meter that, using a directional-coupler, measures forward and reflected power when inserted in a 50 Ω transmission line. But it is limited to CW measurements. The Bird has been the "gold standard" in both commercial and radio amateur practice since practically forever, but it too is rather primitive technology. At the this year's upcoming Hamvention® in Dayton, Ohio, there will be dozens of vendors offering Bird wattmeters and "slugs" for same... along with upcoming clone products.
The Bird is popular, not because it is particularly accurate and inexpensive (it is not!), but because it simply works. Many hams shun the SWR bridge, which is constructed using similar principles, and simply tune their rigs for minimum reflected power using a Bird wattmeter. Among hams, the forward power measurement is mainly for bragging rights, IMHO, because the type of ham who uses a Bird is usually aiming for maximum power output as compared to the ham who pursues QRP operation, or the "minimum power necessary for communication" as specified in the FCC rules for amateur radio.
The Bird 43 is an outstanding engineering item .
So well build and excellent for the job,
practically sells the same product from the beginning ,about 65 years back.
That is truly an amazing thing for a test instrument.
The directional-couplers and SWR bridges are not only used by hams.
Many RF transmitters have them inside for the purpose of automatic antenna tuning or PA protection.
I've seen them mounted at the transmitter output , permanently, at the transmitter end on FM Commercial broadcast installations. I alway's thought they work best connected at the base of the antennae , but not many techs, including myself ,
like climbing 100' towers. Two units in series, back to back lets you read both forward and reflected power simultaneously, then you can calculate SWR.
