X
xray
I'll try not to insult Jim personally, but it
can be difficult, can't it![]()
Very!
Not stupid, just stubborn, stubborn as ... a mule. And perhaps a
little overly resistant to real data.
I don't get the controversy over the beads--kill the real RF, let the
diff amp handle the rest. Seems simple enough.
Doesn't explain where all that energy is going in my little
switcher--57% efficiency, and I can't find the loss. Dang it.
(inductor suspected)
John said:Only from a nearby antenna. I have a set of the old tube GR unit RF
oscillators, from 10 MHz to about 2 GHz, and they output something
like a watt. So you can poke a banana lead in the connector as a
splash-everything antenna, or strip a bit of braid off a hank of coal
and make a more local source you can wave around. It's not
quantitative, but you can find resonances and do a rough before/after
comparison on things.
I've been meaning to buy a real EMI-type antenna, for crude
quantitative suceptability and emissions tests, but haven't got around
to that yet.
Considering you've never seen me !!!!
I assume that your coal was actually coax. My coal never came with a
braid.
Spelling shouldn't count much here, but it threw me off when I read it.
I've been wavin' 'round a coal wand, all the live long day.
Eeyore said:Considering you've never seen me !!!!
Can you still pull 20 somethings ?
Graham
Genome said:I wouldn't be surprised if some of the people you are trying to show off to
have 20 somethings called daughters. I can't begin to imagine a situation
where they might feel the need to waste your time by taking the piss out of
you.
you.
DNA
My own tests were targeted at the AM broadcast band.
We had a sig gen that worked up to 5MHz that had AM modulation.
One of the IEC standards gave a suitable coupling network so the signal went straight up the front end.
No surprise perhaps that FET input op-amps are much less bothered than bipolar.
It can't be done ;-)
...Jim Thompson
James Arthur
Eeyore said:[email protected] wrote:
[snip]
I was concerned over the beads causing unbalance in the interfering signal which
then means that differential rejection will be compromised.
Did you wind you own ?
Yes.
What's the material ?
Jim, you seriously upset a lot of people by refusing to be neurotic.
John
Jim Thompson said:I have 40-somethings called daughters ;-)
As for "taking the piss out of" Eeyore, a 12-year-old could probably
handle that ;-)
...Jim Thompson
[snip]
I got that, but here the remaining imbalance is but a fraction of an
already small error, hence unimportant.
Dunno. After using Genome's handy skin-resistance calculator, I
re-wound a commercial SMPS inductor bi-filar to chop its resistance to
1/4th. The rewound inductor gets warm, but it's so intimate with the
other tiny components it's hard to be sure who's doing the heating.
The original was rated to take my peak current, and now it has half the
turns on it; I measure saturation at >>2x my peak current. Only 1-2%
improvement from the re-wind, which rules out copper losses.
I'm driving the switch from a signal gen, *hard*, to rule out
switching losses. Time to mung in a megainductor and see what's what.
I never did learn to type. It makes me a better programmer, gives me
time to think about what I'm doing.
I want to nominate this for the "rationalization of the year" prize. ;-)
Cheers!
Rich
John said:No, seriously. There's a new school of programming called XP, Extreme
Programming, and one of the methods is to have two people sit in front
of one computer and discuss every line of code before one of them
types it in. The astounding loss of productivity (two people working
maybe 1/10 as fast) is more than made up by the savings in debug time
and the cost of bugs. I manage 300+ lines of tested, bug-free code per
day, even though I can't type and waste a lot of time in newsgroups.
Slowing down is the best way to get programming done fast.
The best way of all is to carefully analyse what needs doing and then code it.
