I have a ball python and I would like to automate his environment!
I plan on making a humidifier controlled by a timer to control the humidity, a heat lamp with a thermostat that will shut off when it gets above 85 degrees, and a fan that will circulate the air that is also controlled by a timer.
I am currently enrolled in an Electromechanical program and will graduate in June, so I have a general background of electronics. The only problem is, I am having trouble envisioning how I will construct the entire thing. I was hoping to maybe get some ideas from more experienced fellows.
The humidifier and the heat lamp is going to be 120VAC, and the timing circuit will be DC.
Any ideas and constructive criticism will be welcomed
