First you need to state the wire size in order to select the correct ring connector for that gauge, next, if you have the terminals already selected, then choose a ring dia to suit.They come 3 or 4 diameter per device.
IOW there are two dimensions, wire gauge and terminal screw diameter in order to select the crimp terminal required.
M.
