Hi George,
This will for students making connections. There will be some strain
relief in the wires. But mostly I figure if they break it they can make
a new wire. I guess at some time the terminal block may break... but
that can be replaced by a competent tech. There will be some
disconnect-reconnect. We could go with just permanent wires.. but then
there are always wires flapping around. And the unit it attaches to
(an LED) will not be used all the time, so some way to disconnect would
be nice.
OK, I'm assuming you've effectively got a cable assembly of sorts
(even if it's just two loose wires) terminating at an LED, etc.
I.e., you are NOT connecting the component directly but, rather,
two "conductors" that you could space at whatever distance is
convenient for you/students.
I look at each solution in terms of something you could mount on the
*outside* of the box so that *it* would "hide your (fabrication) sins".
I.e., so you can drill an *approximate* hole to feed the connection
on the *back* side of the connector to your PCB.
First thought was a small (fine pitch) SINGLE ROW barrier strip with
longish pins on the back side ("long" being defined by how far behind
the enclosure your PCB sits). For example:
http://dgwelink.manufacturer.global...rrier-type/1068554164/9.5mm-barrier-strip.htm>
http://www.digikey.com/product-detail/en/6-1437657-9/A98461-ND/1832527>
http://www.digikey.com/product-detail/en/0387112202/WM7457-ND/3044561>
(I'm not endorsing any of these components -- just giving you an
idea of what I'm trying to describe)
Note that you should be able to let the *enclosure* provide the
mechanical support (instead of transferring those stresses onto
the PCB) as well as "hiding" the holes you drill through the
enclosure.
[Your PCB can have oversized holes through which the "pins" on
the back of the barrier strip protrude so a dab of solder holds
it electrically]
Along the same lines, someone makes what is essentially a "spade
lug" that is 'L'-shaped. I.e., if you fastened it onto a barrier
strip, you would end up with a ~3/4" metal *bar* sticking straight
up (a "wire" would typically be wrapped around the bar -- not
"wire wrap" -- and secured with solder). You could use these
with a regular barrier strip but flipped over (so the "bar"
goes down into the enclosure and provides the means by which your
signals come *up* to the barrier strip's contacts -- to mate with
the individual conductors fastened there).
[Sorry, I can't find a reference -- I'm sure I have some in my
parts cache so perhaps I'll drag out a camera...]
The problems with "wire under a screw" approach are:
- captive screws so students aren't chasing down screws that
they've backed out too far ("Ooops! Where did it go??"
- getting wire around CAPTIVE screw in the presence of any
"barriers" (can be alleviated by some side entry connections)
- *strands* of wire bridging any barrier between connections
Another approach is to use binding posts. But I am not sure how
small they make these -- all of mine are intended for "rugged"
use and tend to be VERY large. These, however, tend to be
easier to use -- eliminating most of the above drawbacks.
http://www.amazon.com/Monoprice-103324-Quality-Binding-Two-Piece/dp/B001TKE25E>
The "push terminals" on the back of some "stereos" and speaker
enclosures also could be of interest. Push, insert wire, release.
http://www.mavin.com/store.php/products/grayhill-29-100-binding-post-120vdc-538>
http://www.hobbyking.com/hobbyking/..._loaded_4mm_electrical_binding_post_pair.html>
You can also consider a pair of test leads terminating in "EZ Hooks",
minihooks, etc. and let students clip those to the *legs* of the LED.
(this would make it easy to try different LEDs to see how they perform)
A lot depends on the *specifics* of your application -- how heavy
the wire will be, how sensitive the signals, how "clumsy" the
students, etc.
Too early in the morning -- I'm fixating on the "color gizmo"
and trying to imagine a bunch of students "experimenting" with
them. :<
If, instead, you want a *product* with a "tethered" sensor, consider
a minijack with the "sensor" a prefabricated, replaceable assembly.
HTH. Time for my morning tea...
--don
