Got some Deoxit on the way and will spray down any suspicious terminals, pots, switches, connectors, etc. Safe to use on/around the PCB if needed, correct?
OK, here's the problematic parts, with photos & links to potential sources, incl spec data :
2SA1124 - needed for BOTH Q613 AND Q629, but you'll see they have slightly diff case markings (photos 1 & 2 below). Not sure if that makes a difference or not, since they have same part #s.
DigiKey can supply with .9w power dissipation rating, vice OEM's 1w rating:
http://www.digikey.com/product-detail/en/fairchild-semiconductor/KSA1013YTA/KSA1013YTACT-ND/4553035
Mouser appears to have one with full 1w power rating, but with a diff pin-out config that now appears problematic:
http://www.mouser.com/ProductDetail...GAEpiMZZMshyDBzk1/WizF0eVyYE44Z5Zqv%2bUsbU6M=
Vetco says NTE32 will work, but it has a completely different physical shape (plus power rating is only .9 too):
http://www.vetco.net/catalog/product_info.php?products_id=3421
I'm thinking the DigiKey option comes closest to OEM part, assuming we can live with the slightly lower .9 power dissipation rating for both locations on the board.
2SB745 - needed for Q625 (photo 3 below).
DigiKey recommends this, but it has diff pin-out config (Base in ctr vice edge) that we'd have to be creative with:
http://www.digikey.com/product-detail/en/fairchild-semiconductor/2N4403BU/2N4403-ND/1418
Vetco says NTE234 will work, and (surprisingly) when I revisited their site I see it has a traditional head shape (vice the round flat head of the other NTE products), AND a pin-out config that matches the original
http://www.vetco.net/catalog/product_info.php?products_id=2862
I'm gonna go with the NTE234 part, since I have to order the obsolete 2OA99 diodes from Vetco anyway.
2SC2632 - needed for Q627 (photo 4 below)
DigiKey recommends this, but it's only rated .9w with a 100MHz transition frew, vice OEM's 1w & 160 MHz freq
http://www.digikey.com/product-detail/en/fairchild-semiconductor/KSC2383OTA/KSC2383OTACT-ND/4213848
Vetco says NTE399 will work, but (again) very different in appearance
http://www.vetco.net/catalog/product_info.php?products_id=3529&keywords=nte399
I'm inclined to go with the DigiKey part, assuming we can live with the slightly lower .9 power rating & transition freq.
Each of the links above has internal links to the spec datasheets if you need to double-check anything.
Although I'd obviously like to get parts that are "exact" matches for the obsolete OEM parts, beggars can't be choosers at this point in the supply chain. As I've reviewed the datasheets closer during preparation of this update, think I've already got a pretty good idea what will work.
Biggest question I have for you (or other lurkers on this thread) is whether the slightly lower power rating (.9w versus 1w) and/or transition freq (100Mhz versus 160MHz) of the above parts will cause any MAJOR problems in our rebuild. If we can live with the diff specs, I've got the full parts list ready to order now.
