That is good news indeed.
When you power up the receiver you should hear a " relay click"
after about 3 seconds or so.
Does that happen?
If so,put the volume knob at it's minimum ,
check the DC voltage(lowest range possible) on the "good "right channel speakers terminals(back panel).
What do we get? Note down that voltage.
Check the DC voltage(lowest range possible) between the center pin of Z602 and both it's edge pins( on the "good" right channel )
What do we get? Note down the voltages.
If the DCV on the speaker terminals is less than 200mV ,
and you have a good speaker that shows resistance of 4 ohms or more(actually check it in ohm test).
You could connect the speaker to the right channel output (only to the right channel,not the left!!!,receiver off) and hopefully get sound, don't crank the volume up too much, just a bit to produce sound at low level.
Do you get sound?Is it clear with no distortion?
If so you can crank the volume higher but not beyond about 1/3 .
When you do get the bat-wings transistors don't install them immediately.
First check them in diode test mode.
Then,you should remove the old thermal grease from the heat-sink .
Was there any insulator(mica) for the transistors?
Carefully(easily breakable) remove it and clean the old grease.
Apply grease to the heat-sink and Trs and install with the mica insulator ,insulator bushing and screws.
close the screws well ,careful not to strong so you don't break the threads!
Now check resistance between the chassis and the TR's pins it should not show a short or low resistance!(means the TR's are well insulated from the chassis ).
At this point please take photos and post them.
After that you can solder the TRs and clean well.
