TDA2030 as a Howland pump?
Martin Griffith
I don't have TDA2030 at hand, and was wondering if using one as
Howland pump would be problematic at say a 150mA, 9V rails, up to 2KHz
I just want to try something out, probably end up in the junk box :(
martin
I
ian field
martin
To save wading through hundreds of google hits on the Howland Pumps plumbing
trade name, here's a NS app note for a Howland pump:
http://www.national.com/an/AN/AN-1515.pdf
Martin Griffith
Hi
That pdf was my first port of call, I just wondering if there are any
gotcha's using a poweramp, as I've never used a Howland for more than
a mA or so before, should have TDA2030 to play with early next week
martin
I
ian field
Hi
martin
There are numerous PA chips that claim to have "the simplicity of an OP
amp", unless you need the current capability of a 20-30W amplifier there are
plenty of 1A power op-amps around - such as the ST L272/L2272 types that can
be lifted foc from older HP/Quantum hard disks.
Martin Griffith
Doh.....thats what happens when you come from an audio background,
think of a audio poweramp first.
(grovelling for some dead Win95 HDD's)
thanks!
martin
I
ian field
thanks!
martin
Don't forget Apple - the old one's used a slightly chunkier SCSI Quantum
with the same head positioner chip.
K
krw
I'm using an LM7171 in a Howland pump, but only about 1/3 that
current. It works great and I have more bandwidth than I can use.
The output impedance is a little dicey though. The Howland needs a
lot of voltage swing from the amplifier though (2/3 dropped by the
output resistor).
