Taking Apart A Television (is this safe)?
Hi
Im planning to take apart an old cathode ray tube television I have.
Television is an amazing device, invented by the great Philo Farnsworth
when he was only twenty one years of age. Should I be careful for
anything specific? Would the selenium be a problem? Chemicals?
Thank You
Marko
The CRT is the primary concern for two reasons: It can implode
sending chards of glass everywhere and it acts as a huge high-voltage
capacitor.
Do you plan to take the TV apart and reassemble/reuse it? If not, you
might want to vent the CRT to eliminate the possibility of implosion.
This can be done by breaking the glass nipple off the neck.
Regarding the HV, even if the TV is broken and/or hasn't been used in
years, there can be enough residual HV on the CRT to knock you on your
butt. There is probably not enough to kill you but it's surprising
what injuries can be sustained when you jerk your hand back after
being zapped with 20KV.
Most people use a long screwdriver to discharge the CRT. You'll
probably note a fat red wire going from the flyback transformer to the
bell (2nd anode) of the CRT. While holding the screwdriver shaft in
contact with the metal chassis, work the tip under the rubber cap of
the 2nd anode connector on the CRT. If there is a charge, you'll hear
a "snap" as it is discharged through the screwdriver to the chassis
ground. You won't feel any shock because you are being careful to
keep that screwdriver in contact with the chassis the whole time.
(Guess what happens if your screwdriver isn't contacting the chassis?)
One note here... even after the CRT is discharged, it can and will
build up a new residual charge - even if the TV is not turned on or
even plugged in. So, discharge it again if you plan to put your hand
anywhere near that 2nd anode connection on the CRT. The charge is in
the CRT, not the red wire.
Also, don't have any expensive electronics near the set when you
discharge the CRT. There is a little EMP that is generated that can
damage some devices. I've lost a few PC keyboards this way.
As far as chemicals, I think you're OK. There may be cadmium in the
phosphor but you're not going to mess with that. There is lead in the
solder - try not to breath it and don't eat it. Wash your hands
before eating. You mention selenium... does this set have an old
selenium rectifier? It's probably not dangerious as long as you don't
eat it. (I guess you can eat a little - RDA of selenium is 55
micrograms according to the national Academy of Sciences - seriously.)
Good luck.
E
Eric
Television invented by Philo Farnsworth?
Are you re-writing history?
Hi
Thank You
CJT
Hi
Thank You
I think the other poster hit most of the high points. I would add that
there can be sharp edges on the sheet metal, pointy wire ends, etc. on
which you can cut yourself. And some of those old chassis are quite
heavy. Tubes other than the CRT break, too, and some contain mercury
and/or other nasties in addition to the obvious danger of broken glass.
I think the selenium rectifiers are a hazard primarily when they fail
and emit gases.
If the set has been powered up recently, other capacitors besides the
CRT can hold a charge.
Occasionally you'll see a part that is spring loaded.
And you never know what else you might find in an old TV. The cat may
have visited, or somebody could have hidden a stash.
L
LASERandDVDfan
You are supposed to arc the anode lead to the DAG, not the chassis ground.
One way is to use a wire with alligator clips, one on the screwdriver and
another on the metal DAG braid usually wrapped around the back of the picture
tube, and then gently insert the tip of the driver under the anode cap towards
the connection point. You'll know when you've discharged it (if it was
charged) when you hear a POP.
It is recommended that you use a high value resistor in the ground path,
though. - Reinhart
James Sweet
though. - Reinhart
The DAG is connected right to the chassis ground in every set I've seen, so
shorting to the metal frame if there is one is generally fine. Most TV's
don't have much of a metal frame though so it's easier to clip the wire to
the spring strap around the bell of the tube that contacts the dag.
James Sweet
and emit gases.
How old is this TV? If it's old enough to contain tubes other than the CRT
or a selenium rectifier it might be worth something as a collectible.
Wow...Thanks guys. I didnt realize that I would have to take such
precautionary measures. The television is a 1999 sony, I believe. It
was struck by lightning and now the image is so tinted that the TV is
not worth salvaging. I just wanted to take it apart, examine the
components and learn. And yes, many people did indeed contribute to the
great invention that is television;
Vladimir Zworykin
Paul Nipkow
G.R Carey
Jons Berzelius
Baird
Jenkins
Philo Farnsworth
We owe a great debt of gratitude to those men.
Charles Schuler
Laughing. Seleniums went out of the picture long before tubes.
Charles said:
collectible.
I have been working on color TVs since 1955 when I was doing some
college work on color prototype sets, even before the RCA CTC-1 came
out. To the best of my knowledge, no color set has ever been
manufactured in the USA using selenium rectifiers. The current levels
were too high and the selenium rectifiers got so hot that they were
relegated to mostly B+W sets and to automobile battery chargers where
they tended to be used with ventilation. The very early RCA - CTC-1
vintage sets used multiple 5U4s.
One early CBS prototype set, non-rotating wheel, built right after the
RCA NTSC format was approved, was a 2-cabinet affair. One cabinet was
just for the power supplies, the other cabinet used a round 16" metal
picture tube with a 12" flat color screen mounted inside the metal
tube. It took days to get the set purity and convergence set up, and
you didn't dare move the set once it was set up because the set was so
sensitive. This was at the University of Florida - Gainesville. I
graduated in 1957, and don't know what happened to that old CBS set.
It generated enough heat that we couldn't run it more than a couple of
hours except in the winter. No air-conditioning in the labs back in
those ancient days.
H. R. (Bob) Hofmann
[email protected] wrote:(snip)yes, many people did indeed
contribute to the
Vladimir Zworykin
Paul Nipkow
G.R Carey
Jons Berzelius
Baird
Jenkins
Philo Farnsworth
If I recall correctly, Zworykin was responsible for the cathode ray
tube, which Baird later attempted to use in experiments with the first
TV signal transmission systems.
But don't quote me on that! ;-)
-Ben
James Sweet
Vladimir Zworykin
Paul Nipkow
G.R Carey
Jons Berzelius
Baird
Jenkins
Philo Farnsworth
Try degaussing the tube, that might fix it right up. Sony makes a good set
and that's a fairly new one.
Jerry G.
I just read all of these comments.
The only very dangerous thing you should be worried about, is if you
accidently break the CRT. Other things to worry about is if there is any
high voltage retained in the CRT anode, and if there are any dangrous
voltages stored in the main capacitors.
It is difficult over an email to describe procedures such as these, in a way
that would be reliably safe for someone else of no experience to follow.
Getting in to a TV set without the proper training and supervision is
something that is not considered safe by any means. In service centers, they
don't even like their experienced technicians to work on sets when alone, in
case of an accident.
If you want to learn something worth while about TV, take a structured
electronics coarse, and then after you do a few years of studying, you may
have enough basics to read some books to get an idea of what goes on in a TV
set.
Taking one apart will not really teach you more than how to take it apart,
and maybe if you are lucky, you will learn about what a mild jolt can do to
you.
Find out from your local city hall about where to take the set for disposal.
This is the safest for you, your family, and the environment.
Greetings,
Romeo E. Albert
James Sweet
set.
you.
Really the best way to learn is by learning to fix them rather than just
take them apart. Contrary to what some say, TV's are not terribly dangerous
to work on, I'm completely self taught as I'm sure many of the professional
techs here are. If I hadn't taken apart TV's to work on them I'd have never
learned how in the first place. That said, read up on the safety first,
there's no need to freak out and go overboard but it is important to know a
few basic rules and have common sense when working on these things. Read the
sci.electronics.repair faq first, then familiarize yourself with using your
DMM, practice some soldering and desoldering, go out and find some broken
TV's, then browse through the TV section of the FAQ again and dig in. Post
here if you get stuck and keep at it, sooner or later you'll get the hang of
it.
CJT
Vladimir Zworykin
Paul Nipkow
G.R Carey
Jons Berzelius
Baird
Jenkins
Philo Farnsworth
I seriously doubt a 1999 television will contain a selenium rectifier.
CJT
I'm not sure how to parse that sentence. Seleniums disappeared before
tubes disappeared, but there were certainly sets containing both.
James Sweet
It won't, or tubes, but that discussion was before we knew the age of the
set.
