If the drain load is resonated and you want some control over the resonant
frequency (i.e. you have external to the mosfet tuning Cs) I don't see much
discontinuities in inductors current. Of course when all the stuff is well
"wired" and that's an entirely different matter, isn't it Paul ? ;-)
John, can you suggest some refs that nicely snap ?
I think that most mosfet substrate diodes are now designed to have
soft recovery, so that they won't snap and make a horrible dv/dt. I
blew up a lot of early Motorola mosfets in an h-bridge motor driver...
had to switch to darlingtons, and only figured it out later.
Anything with a p-i-n structure has a chance of being a snap diode. I
think it needs a hyperbolic doping profile or something to work well.
1N4005-7 types work, but usually only after a brief forward bias, not
DC. Somebody told me that many varicaps snap, but I haven't verified
that. Specifically-designed PIN diodes (the kind used in RF switches
and attenuators) don't snap, as they are doped to have very long
recovery times.
We tested over 60 different TO-220 power diodes to find the best
high-voltage drift step-recovery part. Then we found something else,
much better and more repeatable, but that's still a secret.
