HI - new here.
I am trying to use two ( button ) supercapacitors to provide short term ( about 7 secs ) power to usb peripherals in my car so as to prevent them from dying when the car is cranked.
I am using two 4 Farad 5.5 V supercapacitors in parallel, and these are connected across the input to a usb3 hub being fed from a 12V to 5V / 3A voltage adapter.
I tried to find some info about what I would require to provide 15W for approx 7/8 secs, and I think this should be enough.
So - I am thinking in the right direction here?
When the car is cranked, it disconnects all power to accessory feeds which is running the usb hub.
When the power goes, the caps if charged, should have enough to ''bridge'' the power gap, until power appears again when the engine starts?
However, when power is restored, will the caps not suddenly start draining as much current as possible from the adapter in order to recharge ( i.e. the full 3A ) which will remove power from the usb hub and create another problem?
Do I need some kind of resistor before the caps to reduce current claim?
Sorry for the language - noob![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
pootler
pootler
