Eeyore said:
For starters, the 2 foils are separated by a thin piece of paper, so the
foils
can't touch.
Well...
1) According to what I've read ,the standard aluminum electrolytic cap really
is just a spiral-wound piece of aluminum sitting in a bath of "magic goo"
(initially, it says, a water/glycol mix with an ionic compound such as boric
acid so that it conducts... but these days there's all sort of proprietary
formulas and competition is intense -- hence the whole "leaking caps" on PC
motherboards from a handful of years ago after someone stole another company's
formula and didn't get it quite right), and that sometimes the aluminum oxide
dielectric isn't even formed until after the entire capacitor is constructed,
at which point voltage is applied. It does mention *other* types of
capacitors that use a thin separator (paper, poly-materials, etc), though.
2) The antique radio guys who talk about "reforming" capacitors recommend
using a VARIAC to slowly ramp the voltage up on caps that have been sitting
around awhile, the idea being that without the dielectric is place you really
are looking at something close to a short and applying 120/240V directly will
cause catastrophic failure.
3) In my younger years I'd done the cheeseball "trick" of using two
electrolyitcs "back to back" (polarity-wise) to made a crude non-polarized
capacitor, and it did work in the sense that the cap with reverse polarity on
it behaved as a small resistor.
I guess I'll have to try it out -- I suspect John is correct that "write time"
would be measured in seconds, but still, it'd be fun to do just for the sake
of demonstration.
Thanks for everyone's input.
---Joel
