Analog Kid,
Thank you for a crystal clear as a diamond, explanation. This is exactly what I was trying to understand. I love your clarity it is so refreshing! You get another like, wish I could give you 10 but the system wont let me.
Ps Remember that base station you helped me with? It is finally finished and up and running. Thanks with the alarm circuit!!
Because a Variac basically is a tapped inductor, its current rating is limited by the wire gauge. Winging some numbers here - let's say it is wound with #22 wire and rated for 120 V, 1 A. When you turn the tap down to the 10% point (12 V), you cannot pull 10 A out of there because that 10 A has to pass through the other 90% of the winding, and that still is only #22 wire.
ak
