You're about as stupid as they come,UsuallyWrong.
Platforms
Content
True, but none of that should matter, right? The Q2 winding section
is supposed to be unloaded when Q1 turns on. Essentially no current
flows in Q2, so the Vd(Q2) should match Vd(Q1) nearly exactly.
socialist solder
You are old enough to remember the 2N3055, some of them had their TO3
cans adopt a blue tint from gross overheating, like the exhaust pipes of
a well-seasoned Harley-Davidson. Yet many of those were still good for
more rock sessions.
So you have the peer-reviewed journal articles illustrating a medically
and economically important improvement in life quality and expectancy
resulting from the reduction or elimination of lead from electronic
circuitry, which is traditionally disposed of in landfills, where the lead
content has been proven to leach out into the nearby aquifer?
Socialist Solder, I like it.
It was meant as a quip as much as anything and I apologise to krw if it
was right not taken as such.
The basis of my post is that generally companies are very sensitive to
employees suggesting that they run roughshod over their procedures
without qualification, and to be honest I'm surprised at krw's response.
If I import equipment into Europe I become responsible for it, and I
carry the can if it falls short of the legal standards it must conform
to. Therefore if I knew a supplier had employees that were boasting
they use leaded solder, I'd be concerned as it's trivial to check for
lead free solder by the likes of Trading Standards.
I like that!
It never completely unloads, there will always be capacitances in the
transformer and in the FET.
Bill Sloman said:There's certainly that kind of stuff in the literature. I don't know
how tightly they've coupled lead in electronic solder to intellectual
development difficulties in kids,
but the connection to lead in the
environment (and in the kids) is solid.
Jan said:I thought last night that perhaps he made a layout error and one FET is in the wrong way.
Something like this pad configuration:
0 0
0 0
0 0
would NOT work
Bill said:John Fields isn't spectacularly clever, but he's nowhere near as dumb
as krw, and he's certainly not AlwaysWrong, as anybody only a trifle
brighter than krw would be aware.
The name AlwaysWrong has been attached to somebody who posts under a
variety of pseudonyms, and "John Fields' isn't any of them.
God, you're unbearable. You didn't move to Sydney by choice, I bet
they deported you! Most likely couldn't afford any more brain dead
geezers sucking on the funds.
Jamie
Jan said:Trace impedance
Does that thing have a body diode?
All FETs have body diodes, it is an intrinsic part of the respective
semiconductor production process. The body diodes are, from a current
carrying capability, similar to the FET itself except that you have to
watch dissipation if you plan on using the body diode (I often do).
I wish someone made a back-to-back (or belly-to-belly, depending on
your "orientation") device, to make a true isolating switch, as in...
http://www.analog-innovations.com/SED/PerfectDiodeForChargerIsolation.pdf
or
http://www.analog-innovations.com/SED/OverAndReverseVoltageProtection.pdf
...Jim Thompson
or
...Jim Thompson
http://www.analog-innovations.com/SED/PerfectDiodeForChargerIsolation...
or
http://www.analog-innovations.com/SED/OverAndReverseVoltageProtection...
Jan said:I presume you mean power MOSFETS?
J-FETs do not.
Spehro said:All power MOSFETs (AFAIK) have body diodes, but I think mostly RF
FETs* don't and certainly JFETs don't.
Although free, the body diode is often a PITA since it has sluggish
recovery and has high voltage drop so we often parallel it with a good
diode, such as a Schottky. "FETKY" products combine the two in one
package. The diode tends also to do bad things if power connections
are reversed, often requiring some extra thought and/or protection.
*Eg. BSS83, which has a separate substrate connection. Not sure about
the dual-gate RF MOSFETs.. I think they do not as well.
