mook johnson
As mentioned before I'm working with a design that has a 10MHz push-pull
transmitter to drive a 100 ohm cat6 cable.
The cable is terminated with 100 ohms on both ends and the length is
~200 ft. This is a multi-drop implementation much like RS485 but
needed custom drivers due to the environment.
The driver is configured as a push pull with 5V on the center tap. The
2n7000 transistors are on each leg of the driver and are driven by high
speed logic 5V chips. What I expected to see during transmission on
the centertapped "driver" side of the transformer is a waveform like
this when measured across Q2.
+ _________
+ | | 2X Vin
+ | Q1 |
+ | on |
+----------| |------------| |----------- Vin
+ | Q2 |
+ | on |
instead it looks like this where the drain voltage of Q2 drops to ~
1/2Vin when Q1 turns on.
+ | Q1 | | |
+ | on | | Q2 |
+ |_______| ~1/2 Vin | on |
This of course reduces the amplitude of the "bus" side signal since it
is the difference between Q1 drain and Q2 drain.
Pulses are 30 - 60nS wide.
So instead of the expected +/- 8 - 10V on the bus I am getting +/- ~2
What I've already looked at.
1) the signals look like a current driven push pull push pull power
supply. So I removed the transformer and shorted the two drain
connections together and measured inductance. (singe nH range. < 1 ohm
XL). I measure the CT voltage with a scope and it is rock steady, 10uF
ceramic directly from there to ground to insure that.
2) Changed the frequency down the 5MHz to see if it is a reflection of
the pulse. Signals look identical just 2x wide was expected.
3) checked insertion loss, with an impedance analyzer and it looked
good. < 1dB
4) Q1 was removed and replaced with a ohm ranger (semi flyback style).
and the lower the resistance got, the higher the amplitude seen on the
bus side. until transformer saturation.
There is something going on with that transformer I'm sure of it. It
was designed by a 3rd party that has RF experience and they are
convinced that it is some kind of RF/transmission line matching issue.
I tend to think its more simple than that.
Any thoughts?
+ _________
+ | | 2X Vin
+ | Q1 |
+ | on |
+ | Q2 |
+ | on |
+ | Q1 | | |
+ | on | | Q2 |
good. < 1dB
Any thoughts?
