L
Landline
It really is all pretty damn simple - the guy with the most toys wins
wmbjk said:Not anymore apparently, but check the archives... about a year ago we
had this same discussion about the usefulness and affordability of
Kill-a-Watt, Wattsup, etc. George started out arguing that his
breakout box method was just as good, but changed his tune eventually.
How did he forget so quickly? My guess is that tiny marsupials sneak
into his room each night and steal portions of his mind. Perhaps
they're stocking the pieces to build a very tiny but scary DMV droid.
Wayne
wmbjk said:Yes, which is why he bought a case of Kill-a-Watts, and makes
effective use of them. He disagreed with your whole "toy" line of
reasoning, so what was your point again?
Wayne
wmbjk said:The dividing line between a 400W inverter being a "toy", or being a
critical part of a custom home's "system", is apparently so fine that
one must be a "solar power consultant" to see it.
Wayne
daestrom said:Does you clamp meter include a timer so it can integrate the instantaneous
power over time and display the actual energy used in kwh??
daestrom
wmbjk said:When a device like a Kill-a-Watt meter is needed (for appliances whose
load changes over time, such as clothes washers, dish washers,
computers, etc.), a clamp meter is a tedious and highly ineffective
substitute. Making such a substitution is pointless anyway when the
proper tool costs so little. Not to mention the embarrassment of
getting caught pretending to be a professional for not only doing
without such a basic tool, but scoffing at others for having one.
Wayne
Nope that does not make two days autonomy either. Try again.
Steve Spence said:Steve Spence
Dir., Green Trust
http://www.green-trust.org
Not oo often, but it happens. This wasn't one of those times.
That regulated power supply won't work real conveniently with my digital
camera, or my son's xmods.
So
Do you have a clue how useful this tool is? When a customer wants to
know how much a microwave draws, and how often they use it in a week,
what would you use? I bet you guess .....
I have a digital multimeter for that. This is for testing 120vac loads
over time, and the frequency setting is nice for tuning the governor on
the generator.
Having it all in one box is convenient for the uses I need it for.
As it turnes out, Yes.
Then why did you call it a toy? And why do you feel the need to find
something wrong with owning and using one?
Looks flash when you show it off, eh.
You might explain exactly how *you'd* measure the energy consumption
of a dishwasher *without* using something like a Kill-a-Watt. Let me
guess... the "professional" and convenient breakout box/clamp-on
meter/stopwatch/pen and paper/sit and wait/calculator method? That
would look flash when you show it off... until your customer finds out
that you only do it that way because you're too pigheaded to spend $25
for a the proper tool (http://tinyurl.com/47o95), or $5 for a surplus
house meter. But we shouldn't discount the most likely possibility -
that you've never measured the energy consumption of a dishwasher.
Wayne
wmbjk said:Then why did you call it a toy? And why do you feel the need to find
I didn't. Steve did.
Why don't one of you experts, that mouth off tell me how you use a
Kill-a-Watt unit to measure the load of a dishwasher when 99% of them are
all wired into the circuit?
Steve Spence said:I don't see a problem using 2 KAW's, as long as the load isn't more than
15 amps per leg. Using the transformer idea would work as well if the
load was less than 7amp. Just have to do some math with the readings.
Steve Spence
Dir., Green Trust
George Ghio said:Did I claim that?
Philip said:hmmm... for smaller loads (10A/240V) you might be able to use a
120->240 transformer. Plug the 120 side of the transformer into the
KaW, and wire a 240V receptacle to the 240 side.
m II said:You may want to draw that out on piece of paper. Keep in mind that the meter
has to read voltage, current and power factor.
This may prove to be a bit harder than a first look tells you.
wmbjk said:I didn't. Steve did.
Steve used the word as part of a useful contribution, and you've used
it to advertise that you'd rather quibble and struggle than shell out
a few bucks for a basic tool.
<place holder for "solar power consultant's" invisible explanation>
IOW, until Murphy gets a dishwasher, his "consultant" don't need no
steenking Kill A Watt, preferring instead to squander his hours
protecting Usenet readers from those who would mention useful and
affordable gadgets.
Wayne
Lucky for us the power company provides a
meter that measures everything.
