It has six nice audio amplifier stages which you could reuse. Four channels on the main board and two more on the rear amp board. It looks like they run from ±60V so they'll be able to deliver quite a bit of power!
So I would keep the power supply and power amps intact. Much of the rest of it will be dependent on the devices on the digital board, but there may be some more sections that you can salvage.
You're lucky that the full service manual is available. It would be a good place to start if you want to learn more about electronics and you can find an application for it. The outputs are specified for a 4Ω load so you could make a pretty powerful instrument amp (guitar, bass, keyboard etc) from two of them running in BTL (bridge-tied load) configuration. If you want an instrument amp, that is. It's just a suggestion.
