Sony KV-1370R broken Antenna Isolation Block
Dave
Greetings All,
One more post...Continued from last week .
I have an otherwise great TV with a broken F-connector. Last week I was
advised by this board to abandon the repair attempt on the antenna isolation
block, and to secure a replacement part from either MCM or a local repair
shop.
I went to a local TV repair shop, got an antenna isolation block, and put it
in. Just out of curiosity, I hooked my DMM and measured AC volts to a hard
ground. The new part seems a bit leaky. On the "repaired" TV, I measured
about 63Vac. I took a survey of the other TVs in the house and all had
undetectable voltage between the F-connector and a ground (with the CATV
cable removed). Is it possible that the TV guy sold me a lemon or are some
of these less just a little more leaky than others? Is this normal behavior
for these parts, or should I get another part from the TV guy?
Dave
RonKZ650
You can't simply read AC between ground and equipment to measure AC leakage.
All Hot ground equipment will measure at least 1/2 line voltage to ground. In
other words, don't worry about it.
Ron
Alan Harriman
cable removed).
To measure AC leakage, "connect a 1.5K ohm, 10w resistor paralleled by a 0.15uf
capacitor between each exposed metallic part and a good earth ground". The
voltage across the resistor must be less than 0.75vac.
Also, make sure it's truly an isolated antenna input block.
Alan Harriman
