I've found a bunch of posts on here, and via Google, regarding this TV
and convergence problems. Most suggest that replacing the two STK392-
xxx ICs (110, 150, 180, 560 - mine are 560) and some fuses as the
solution.
That makes sense - the explanation is that the ICs go bad and take out
the fuses, resulting in no convergence. Fine. I can stomach that. But
my convergence is FINE when I turn the TV on, and flakes out shortly
after it heats up. Am I wrong in thinking that BLOWN ICs (and fuses!)
would cause a problem that would be consistently present from the
moment of power-on?
I'm not 100% sure of what happens to boards when CRT coolant gets on
them - but I do know that, at some point in this set's history, there
has been a leak. It appears that some got onto the board near the
leftmost (looking at it from the front of the set) convergence IC.
What am I looking for?
solution.
moment of power-on?
