Hi,, i wonder if anyone can advise how solve my problem...
I have a Omron timer H3CA-8,, my problem is,, i live in rural area, and the mains power is not very stable or reliable..well what happens is when there in a power interruption,,, the timer atomatically restarts..
so for example,,, it it was set to turn off the item after 1 hour.. then,, if in 30 minutes, there is a power disruption, even if just for a momnet.. then it will start again for another 1 hour..
so obviously that is no good if yu want a definate time to run something..
The same thing if the timer has finished it's timing cycle, and there is a power disruption, then it stats again...
i was thinking that maybe there is a power detection curcuit , that i could use,that will stay switched off and have to be manually reset after a power disruption..?
or some switch that maybe i can buy that would do the job..
or even, wud it be possible to use some big capacitor to keep the power maintained to the timer?
Any ideas would be hight appreciated............. thanks..
