M. Hamed
I am not new to soldering. I have some soldering experience. I have built aradio kit with no soldering problems whatsoever. I have made little boardsfor things like transistor amplifiers for my crystal radio. I have little surface mount experience, but in a moment of extreme courage, my boss let me rework about 50 PCBs at once when he was on vacation. That involved soldering a little SMT cap using tiny little wire to a nearby IC pin. Most of the boards worked, but the job looked horribly ugly.
The reason I consider myself still a newbie, is that successes are not always repeatable, and failures are not always avoidable.
I have read numerous guides on the Internet but some things really don't click. I thought I could start this thread to ask questions that will probably be obvious to some but still not very clear to me.
The questions at hand for now are these:
1) Soldering guides always recommend you to tin the tip of your iron with fresh solder before starting on a joint. Every time I do this the solder burns and discolors. Is that normal or am I doing something wrong? Do I have to be really fast before solder burns?
2) Soldering guides tell you to always heat the joint not the solder. Whenever I do this, it seems it takes forever for solder to melt. It also seems that the pointy part of the tip (as they always show in drawings) isn't really hot enough I have to find a sweet spot on the tip that is hot enough and then touch it to the wire. Do I just have a bad iron?
3) Can I use copper wool instead of a wet sponge? I have been using it recently with success. The problem is that I'm not sure if it's better than a sponge or not. I'm not even sure of the function of the copper or the sponge.. I know it's for wiping the tip clean but it's hard for me to gauge how much better cleaning the tip actually provides.
4) When to use flux and when is it not important? I soldered the transistorradio kit completely without flux. But also the type of solder they provided with the kit seemed really good, I thought may be the solder has it all.
I know this has been answered a million times before but if someone is feeling bored may be they can share their experience. I know I probably can spend hours scouring internet forums and getting all sorts of conflicting information. I thought I may get some direct answers here! THANKS.
