I just purchased a 4-digit, 7-segment LED display as shown in this tutorial, which is compatible with the Arduino library TM1637.h. But I'm having trouble with the 4 pins that insert into the 4 holes on the side of the display. I tried soldering them into the holes but accidentally caused a short because the solder spread across 2 of the holes, causing it to stop working. In fact, I couldn't even find the COM port when that happened, probably because of a short.
I started over with a fresh display that isn't soldered and when hold the pins in the exact right way, all the connections are established and it works just fine. But I have to sit here and hold it just right. So, how do I go about soldering this so that all the connections stay in place? The holes are very small and close together and It seems almost impossible to get it just right. What am I missing here?
