Software to control COM or Parallel port pin output
Is there software that can allow me to "ground" (and unground ???) a pin on either a com port or parallel port on a PC using Win XP?
(not USB)
A little OTT but the free Mach3 CNC would control P.P. outputs, the relay may be to high a current for a P.P. but you can use a 2n7000 to drive it with.
You could also use a COM port for RS232 if using a outboard μp. such as PICmicro or Arduino etc.
Max.
You may be better off looking at building a small application in C++ (or another language) to do this for you.
There are many 'Parallel port test' apps available for windows, they typically require the .Net framework, but I am not aware of anything that you could possibly do much 'custom' with aside from clicking it yourself with a mouse.
Try reading this page : http://www.codeproject.com/Articles/75279/Channel-Logic-Analyzer
CDRIVE
(not USB)
Does your XP have Hyper Terminal in the Accessories directory?
Chris
CDRIVE
On second thought Hyper Terminal may not be much use on its own because it was basically designed as a DialUp app for intended Modem use.
Let me look through my VB6 files. Over the years I wrote quite a few MSComm (Serial Port) programs. I may have one already written that will fill the bill. Even if I don't (doubt it) it wouldn't take me very long to write it. I assume you'd like a button on the app to switch the pin High - Low? If you like I can give you 3 output pins with a button assigned to each. I will be using the DTR, RTS, and TXD pins. You will have to interface the pins with 3 transistors.
Chris
