Sarah E. Bailey said:
Oooohhh
=D
Hello there Sarah ! A girl/woman which knows stuff about computerrrrsss
that's rare !
=D
I've followed your antics over the last few years and can only think that
it's
You have, have you ?!
=D Well I am glad you enjoyed it secretly !
=D
your instinct for instantly jumping to totally unfounded and unrelated
It's not my instinct, usually I try to find most likely cause, but since I
know very little about electronics I simply shutgon the shit out of it with
all kinds of whacky theories... I mostly to do this to be able to tell the
bad from the good... bad people will believe the shit... good people will
not... though sometimes I might even be on to something or inspire people to
think outside the box
conclusions to perceived problems that produce all your troubles in the
first
Your theory that my conclusions are unfounded and unrelated are interesting
and therefore I investigated it based on my messaging archive and am still
investigating it further... it will discuss down below further.
Some of the problems I saw a real like dust build up and perhaps also heat
build up but if these problems actually lead to system death remains to be
seen/proven.
place! I can't for the life of me understand how you manage to destroy so
much
computer hardware.
Neither can I though I have indicated sometimes that most likely cause of
failure was electrical damage somehow and not necessarily heat related... I
plan on replacing the bad wall sockets with grounded wall sockets to try and
rule out that possible cause of damage. I shall have to consult my "land
lord" or "appartment rent seller" or whatever it's called in english if it's
wise to do so... I will probably try and do so anyway... unless a grounding
cable is not available... then it becomes a bit of a problem... but my
kitchen has grounding cables it seems... so the first real possibility which
comes to mind is using a really long power extension cord but then it would
run a little bit through my kitchen and over my floor but it wouldn't be too
much of a problem to actually do that. Except that one plug would be upside
down in the kitchen there are two holes available... and the bottom already
used by magnetron/wave so that plug is a bit in the way or something, and if
new plug is upside down it might get loose, so it would depend on the plug's
shape if it's possible or not safely... but there are probably power
extension boxes/plugs which are shaped nicely so they can fit in any
direction/any hole.
Before you do anything else, get your home rewired with Euro standard
Schuko
type F Earthed sockets.
Yeah this is a good plan... before I do anything else I need to fix my home
first which might be the cause of all damage.
That will help with your suspected 120V floating cases
problem, although why you should think the Euro standard 230 Volt mains
supply
will get divided by 2 seems strange to me.
The case's power connector or something... divides it in two... maybe to
fluctuate between +120 and -120 volts... which might be safer in case of
touching it... the mussles don't go in one way but both ways which makes it
easier to let go when human put under charge.
The circuit is explained here, but it doesn't completely explain why it
divides it in two... but I read another webpage which mentioned that this
might be safer for mussles so maybe that's why... (not
http://www.radionics.demon.nl/pc_aarden/aarding.html
This page is dutch explains "fluctuating power" is better then "steady
power".
http://nl.wikipedia.org/wiki/Elektrocutie
I've been running what is essentially the same motherboard as you (an Asus
A8N
SLi Deluxe) with an AMD Opteron 170 Dual core processor (90W) overclocked
to
According to this wikipedia webpage it has a TDP of 110W so to me it seems a
bit dangerous to overclock it
2.75GHz since 2006, in a smaller Cooler Master Centurion 531 case, with 5
Only 2.75 GHz ?
Mine is 2x2.0 GHz !
=D
That case is alluminium and buckles fast, not a good property to have for
the daughtercards/extensioncards they might pop out.
harddiscs, a DVD ReWriter and a 3½" combined floppy drive/memory card
reader. I
Why 5 harddisks what you doing with it, collecting porn ?!
=D
use The similar nVidia 7900GS video card, and a Seasonic 600W PSU to run
that
Not sure how much that card uses in power and outputs but my guess would be
60 watt or so... my gtx 7900 seems to be 80 watt or so. Watt=heat.
lot. The only thing I don't have is a separate sound card in there,
although I
No sound card ? But your motherboard does have onboard audio ?! So do you
play any games ?
I guess you have a "simple" stereo device connected to it, while I have had
a gigawork s750, which is about 7x80 watts or so... which is a lot of power
being attached to my pc in a way... and later on a receiver which is also
about that wattage... so there is another power hungry device at play in my
situation.
did at one time run a second 7900GS card in SLi mode, but didn't find it
made
much difference.
I did too with two gtx 7900 it helped in cod4 with +10 to +20 fps or so...as
well in battlefield 2 +5 fps or so.
But that's a lot of extra heat so I got rid of it in favor of soundcard
which was in between too.
So instead went with one card.
Why did you remove it anyway ?
The only problem that I've ever had with it is that the Deluxe
motherboard,
unlike your Premium version which has a heatpipe, suffered from dying
chipset
fans,
Could be a sign of heat trouble... the oil in the fan probably dried up
causing it to fail... perhaps in combination with added dust and micro-dirty
making it stuck or so.
so I rigged a small 60mm fan attached to the video card cover to blow
onto the heatsink of the chipset, from which I'd removed the fan. Since
then
it's been fine!
Sounds like the trouble I had with my chieftec case at the time which got
replaced by the antec 1200.
How did you manage to "rig" that fan in there ? How did you attach it ?!? A
picture of it would be nice to see !
=D
I'm going to build my new i7 system in the very same Antec 1200 case that
you
I would not recommend the i7 because it's a very hot chip... instead I would
go with one of the low powered Core i5 chips... the low powered chips work
just as fast but they are a bit more expensive. I would go with the 35 watt
versions instead of the 90 watt or even higher versions... My pentium III
450 mhz was 35 watt and it's still working after something like 13 years or
so ?!?
use now. That case is HUGE!!! How you can possibly get your system to
overheat
in that I cannot imagine!
This case has dust and slight sound issue's... putting it on all high fan
speed will make a lot of sound...
Medium fan speed gives nice airflow but it's not an "all fixer" tool...
things obstructing the airflow can still lead to higher temperatures which I
wouldn't feel comfortable with like +40 motherboard temperatures and +45 cpu
temperatures.
The dust filters also get easily stuffed with dust... all these fans causing
lot's of dust... I live in dusty place... I don't vacuum clean that often...
therefore this case and this "over powered pc" might not have been a too
smart idea for me... but I wanted to give it a try... I had loads of fun
with it, that puts smile on my face... but it also caused some shitty
situations like now... all in all it was worth it from the fun
perspective... but I have one little problem... I would like to keep it
alive... and in that regards it kinda sux... I am also getting "old" I am
not really old... but my energy levels a bit low... perhaps I should
excersice more and perhaps I will... but I am getting a bit fed up with
having to "fix" this computer every time... it just takes a lot of time to
figure out what to do about it... so I hope to fix it... and hopefully once
and for all... but I fear that won't happen... but at least I can try and
make things better a little bit.
The dust creates extra risks:
1. Cannot put case on ground... if you would... it would suck up a lot of
dust I bet ! Thus must be placed on desk... hitting desk could lead to
harddisk damage... so it has risks... overall it's probably better to buy a
case which can be placed on the ground and therefore I would still consider
this antec 1200 a bad case in general... that's why this heat issue might
not even be a direct problem... but it's leading to all kinds of other
problems... which might ultimately lead to serious problems... like
overheat, cleaning issues, static elec issue's and perhaps even fire.
2. Having to clean the case and open it to get dust filters out (cpu/window
dust filter) and pulling out harddisk trays to get near the front dust
filters introduces further risks: damage risk to hd when pulling it out...
and static electricity risks. I even vaccuum cleaned it a little bit which
is dangerous because of static elec coming from it but I kept it at distance
few centimeters but who knows... elec might still jump over.
3. Low fan speed might still not be enough, especially in summer... my place
gets 7 degrees to 10 degrees hotter in summer... so that might be big
difference compared to your situation if you life in a cool place !
=D
Fortunately antec 1200 has "high speed" so that can fight the heat a bit
4. Large cpu coolers are a bad idea... they obstruct more airflow then they
solve... especially the passive cpu heatsinks.
5. CPU heatsinks/gpu heatsinks get full with dust and might reduce
effectiveness and might create hotspots.
Unless you really do have so much money that you can afford to throw even
more
I don't wanna spent to much money because then I would look like a fool !
=D
away on yet another new system to wreck, I'd suggest that you take the
advice
I'd rather not get a full new system... I am starting to run out of space to
place it... though I'd very much like a new core i5 processor and cuda
gpu... but I spent so much money on my dream pc that I should probably stick
with it for another few years just to keep the trend going... the trend is
5000 bucks per PC per 5 years... I sort of spent near 12.000 bucks/gulders
(6.000 euro's) on this PC in 5 years... bucks=was gulders... but because of
the euro it was doubled... didn't really realize that until I bought the
system lol !
=D so I guess I went way over budget !
of myself and others here lately, and buy yourself a Dell or something
else
I'm afraid a Dell has way to many driver issue's, perhaps shitty hardware
issue and would be way to weak for my purposes and then I would get annoyed
with it real fast, start hitting it and then it would die !
=D
readymade, and have the case welded shut!
I like this idea of welding it shut... unfortunately then I can't add
harddrives, which is a nice thing to do
Having said that, I would miss the comedy to be had from your future
posts!
Don't worry about that... lot's of comedy will always be coming forth from
me
Thank you, I wish you lot's of luck with your new system as well... are you
getting nervous with your current system, or you scared it will die too, are
you having nightmares about the dead cpu fan ?
Why are you building a new
system ?
I can't advice you on a better case since I haven't looked into it yet...
but if I were to buy a new case I would try to buy one which I can place on
the ground... maybe I would even buy extra long cables so I can keep it away
from me as far as possible... and I would try to place the case somewhere
where there is little dust build up... but dust usually creeps and lands
near stuff anyway.. Also the human body sheds dust particles and these get
sucked into the system if it's near a human being... so it would be better
to try and keep the pc as far away as possible... There was a huge ammount
of dust in the antec 1200 case... I don't like that one bit !
Some dust
is ok but this was a bit (too?!) much.
Also if you do decide to get it... then be sure to remove the inside plastic
near the third fan duct... there is this special black removeable thingy...
it's only there to hold internal fans... if you don't need/place internal
fan then it's probably better to remove it... for better airflow
Is this your little secret pseudoname ?
Also I don't meet that many woman that know stuff about computers... it
would be interesting to see how you look like
If you wanna see how I look then send me a picture of yourself to: skybuck
2000 at hotmail dot com... If I like what I see I might send you a picture
back of myself
Perhaps with a little text which would read: "Hi there
Sarah E !
=D" so you know it's real... if possible you should do same
thing and make special picture which reads: "Hi there Skybuck, it's me Sarah
=D".
You don't have to get on it immediatly... for all I care you spent this in a
couple of months... if you never send it that's ok too !
=D
I do wonder how old you are ?! If you don't wanna share a picture then
perhaps you wanna tell us how old you are ? But I guess that's a bit of an
indecent question to ask a woman !
=D
I googled you a bit and I also saw you use RISC OS ?! Never heard of it but
read up onto it... and it seems kinda interesting... old/under
powered/developed/few features... but still kinda interesting... perhaps
if/when I get my PC working again I might give it a try with bootable vhd's
or virtual pc's/vmware/emulatators or so... to see what it is and how it
works etc... I probably won't be too impressed by it... but still fun to
give it a try out of curiosity.
Take care and may your electronically enhanced bra lift you towards
un-imaginable success !
=D
Bye,
Skybra =D
