Paul Hovnanian P.E.
You can cool your PC quite efficiently without all that fan noise by
immersing it in a bathtub full of water while playing games.
Quit talking rubbish.
He is posting of his adventures with his broken computer in computer
and electronics groups control freak.
he is talking about his efforts to fault find his computer in
perfectly appropriate groups.
The only person who needs reporting is YOU!
Ever thought of kill filing folks you don't want to read?
Paul Hovnanian P.E. said:You can cool your PC quite efficiently without all that fan noise by
Charter? BWAAAAAAAAAAAAAAAAAAAAAAAAAAAAHAHAHA FUCKING HAH you got to be
kidding me? You think a charter is anything but a guideline for posting
and that somehow is enforceable? Do you know how many different charters
there are? I would take an educated guess and say it's greater than 80 or
so thousand. Abuse departments hardly ever respond to tangible complaints
like spamming, forgery etc.. let alone off topic posts you Fool. Figure
out how to use your newsreader kill filter or use a wet kill filter (your
brain) and just ignore what you don't want to read.
Skybuck Flying said:Or maybe not... kinda makes the same sound.
Or maybe with case closed, the fans spin a little harder oh well.
The heat probably higher though with case closed
Also placed another book on top of the case to make it more heavy..
reduces any vibrations![]()
mr said:WRONG
This is DANGEROUS, DONT DO IT....
the water can get into the keyboard and ruin the membranes that allow you to
type!..
I think the standard is 1 charter per group
so if he's posting to 80,000 groups then yes, there's probably 80,000
charters..
But as we look at charters, only 1 charter needs to apply, and that's the
charter that applys to the group his post is in, even if it's in 10 groups
then only 1 charter per group can apply....
Hopefully the new motherboard will now last longer than 1 year and 3 months.
Marra said:I always leave both side plates off.
You spelled Membrain wrong! :-]WRONG
type!..
Skybuck Flying said:Hmm that was interesting.
I was playing Battlefield 2 and the motherboard temperature was 49
degrees.
I decided to open up the case and remove the plate.
A few seconds later the motherboard temperature was 51 degrees !
So actually removing the plate was a bad idea !
The fan probably starts sucking air from around it...
Apperently the case has to function as a tube !
To suck air over the components !
So case door closed is actually better !
Craig Sutton said:Nope, the cause of all YOUR problems is YOU.
And get rid of the pathetic Battlefield 2 game.
Of course you should also know that having 2 video cards heats up the area
around the m.b heat sensor.
Why should I?
**** off.
My apologies to AMD.
It's not AMD's Cool & Quiet feature which slows down the fan.
It's Asus's Q-Fan Control which slows down the fan !
SORRY.
Bye,
Skybuck.
41C = 6000 RPM
