W
Walter Harley
If it's just to indicate power is on, why not use a flasher of some
kind? The average power can be made quite low. Numerous designs have
been posted to alt.binaries.schematics.electronic
You ever try to play music at one tempo, while something is flashing at a
different tempo?
I did play around with just pulsing the LED at a rate too fast to see the
flicker, but perceived brightness seems pretty closely related to average
power, so that didn't buy me anything.
I have actually had suggestions to use the power LED as a metronome. But a
metronome that can't be turned off is painful to work with; and actually,
it's hard to synchronize well to a blinking light - audible metronomes work
better than visual ones. The visual ones distract without aiding.
One thing you sometimes see is LED's that turn on if the battery is getting
low; or, that turn on briefly when the device is turned on, and then fade a
second later (but don't turn on at all if the batteries are too low).
Informal feedback I got from musicians was that they'd forget to turn it off
if I did it that way - too bad, it would be very easy to implement, and
power-efficient!
The device at present is turned on by plugging an instrument into it. This
is actually a bad scheme because it means I can't use an ordinary
inexpensive input jack; but it corresponds to how most guitar stompbox
effects work, so my clientele are very comfortable with it.
Speaking as an amateur musician myself, I hate to denigrate the intelligence
of my customers - but let's just say that musical brilliance is often
accompanied by technological clumsiness.
The altogether best solution would be to automatically turn the power on
when they're playing, and off otherwise, and not worry about a power LED.
But I worry about RFI and whatnot causing it to inadvertently turn on. I
suppose I could work that out - maybe that's where I should focus my time.
(But I do need to learn about switchers somehow!)
