W
Winfield Hill
Michael wrote...
Thanks! When Q4 is on, the LED current increases until the sense resistor
voltage is Vhi = Vbe1 - Vd R2/R3, which you can design to be about 250mV.
Then when Q2 turns on and Q4 is off the LED current decreases until the
sense voltage is Vlo = Vbe1 - Vd R2/R3 - (Vd-Vbe) R2/R4 which could be
say 200mV, creating 50mV of hysteresis. With an average voltage of 225mV
and R1 = 22 ohms we get an LED current that ramps from 9 to 11mA and back.
Let's evaluate the inductor voltages. With Q4 on we get Vbatt - Vd - 0.22,
or about +5.7V with a 7.5-volt partially-used battery. With Q4 off we see
-(Vd_LED + 0.22 + Vd1) or about -2.1V. So the inductor charging times will
be about 1/3 as long as the discharging times. Let's design for a 200kHz
switching frequency, or a discharge time of about 3.7us, during which L1's
current drops by 2mA. From dI/dt = V/L we can calculate L = 3.9mH
Thanks,
- Win
whill_at_picovolt-dot-com
Winfield Hill wrote ...
R3 is to lift the base of Q1 slightly so you only need to drop less
than .6V accross R1, the circuit would work without it but would be
less effecient. It's a nice circuit, I like it.
Thanks,
- Win
