I have a DIY cooking project with which I'd appreciate some
help.
<snip>
Many thanks to all who troubled to share their thoughts. I
thought I would be lucky to get even a single reply, but in
only a few days there have been fifteen from almost as many
individuals.
Rather than reply to each individual message, I'll try to
clarify matters with a single response. I hope everyone who
replied will see this contribution to the thread.
First, to respond to Ecnerwal
Zeroth question - other than you fussing about
it, is this really all that big of a deal? Few
cooking or culturing processes care all that
much about a lousy degree, F or C.
And Rich Grise
I wonder what he cooks at 130°F ± 0.3°F! =:-O
Over the past several years, within the general realm of
"molecular gastronomy" exists that of "sous vide" (French for
"under pressure") cookery.
Misleading nomenclature to the contrary, what this is really
all about is instead of cooking, for example, a beef roast at
350 degrees and removing it when it reaches the desired
internal temperature, it's wrapped and placed in a water bath
of the desired temperature (130 for example) to begin with.
It's then cooked not just for hours, but sometimes for days.
Okay, what's the point?
There are several advantages (google to acquaint yourself with
them) but among the most important is that, as in pit BBQ,
this "low and slow" cooking has a tenderizing effect, offering
the chance to turn the lead of cheap chuck into the gold of
rib eye and having it STILL come out medium rare.
Being a somewhat new approach to cooking, however, it simply
isn't known what effect temperature fluctuation has on the
process. The general consensus is that less is better. I knew
when I bought the thermostat that it only allowed a .3C
variance and was content with that.
Many have used a PID controller, as whit3rd noted, but I
thought that even though it allowed much greater temperature
stability, its complexity was beyond my capacity to properly
configure.
When I discovered that my STC-1000 thermostat exhibited a
small but significant overshoot, I thought it was probably
acceptable but I wondered if there was an easy way to reduce
it.
One obvious approach was to keep the heating element from
getting so hot. I now realize that a simple resistor simply
won't work, it would have to be massive to reduce the current
by the required amount.
I'd like to use a less massive heating element, as Sjouke
Burry pointed out, but finding something ready made that can
be immersed in water, isn't so easy. A home aquarium heater
can be hacked to remove its thermostat, but this isn't a
project I'm comfortable doing.
Rich Grise saw a good solution
It looks like $5 spent at Home Depot should do the trick.
Mikek had another insight...
Not sure I like the idea of pumping 72* F air bubbles
through a system I'm trying to keep at constant 130*F.
And John Fields...
Are you using the air pump as a bubbler or as a
recirculating pump?
To mix the water.
Originally, I tried placing the stockpot on a hot plate
(connected to the thermostat) without the bubbler, hoping that
natural convection would do the trick, but the overshoot was
pretty bad. Adding the bubbler helped, but using the immersion
heater and bubbler was the best solution so far.
Cooling the water by bubbling room temperature air through it,
I knew, wasn't such a good idea, but the only economical
alternative I could think of was something like a submersible
tabletop fountain pump, like a Sunterra. The question was
whether it would tolerate such hot water. I emailed the
company and inquired, but received no response.
Rather than delay any longer and worried about mixing
electrical current and water, I thought the air pump, despite
its disadvantages, was probably the better option.
Perhaps some who have followed this thread may have a thought
on this topic. Would one of these tiny submersible pumps
function at 130F temperature? For very long? Would it simply
fail and need to be replaced or result in some disaster?
Anyway, for less than $50 - compared to $1400 for a Fisher
laboratory circulator or even $400 for a retail Sous Vide
Supreme - I'm cooking sous vide.
And very happily too. Like pit BBQ, of which I am also a fan,
my few attempts so far have revealed that it can create
genuine culinary magic.
Thanks again to all for so generously sharing their knowledge.
Jesse
