It's really hard to tel. I thought that heatsink was going to be MUCH larger.
The dimensions of this heatsink are 30X55X20mm... That's 33cm^3, right? So how much degC/W is that? I'm really mad that the manufacturer doesn't give that info for the product...
(also, measuring the voltage drop across the mosfet would be useful too. You can then determine the actual heat being dissipated and compare this to the results you got from the datasheet.
To get the voltage drop I would have to measure the D-S resistance, right? Wouldn't it change when I start putting current through the element - e.g. I'd have to measure the resistance "on-the-fly" as I do the test run. Meaning I'd have to attach a multimeter across the terminals with current going through them, which as far as I know is a no-no... How would you go about doing this measurement?
If I'm able to get my hands on an IR thermometer I'd get a much clearer picture of the situation, but after seeing the results I don't think its a must since the FET doesn't even get warm...
As for the efficiency of MOSFETs vs regular Bipolar transistors - I've taken a few shots of the PSU's radiator and the mounted transistors:
Comparing this sink to the one, fitted to the FET - I'd say... WOAH
I know that the Bipolar transistors actually do have more power through them, but the efficiency difference is undeniable and its most definitely the FET's ball game
Ironically, one of the assistants at the University I spoke to regarding my project told me I'd be better off using Bipolar transistors He really couldn't explain why but to me it was just a matter of him not having enough knowledge regarding FETs. To me its as clear as day that FETs are the way to go in this application - they're more cost-effective, easier to implement and more electrically efficient. Enough said
I was rather curious as to how much current I'd be able to push through the FET without it getting hot, but as I already said I won't be able to get much past the 4A marker with my electronic PSU. I do have another one - an old pre-transistor age supply which I'm currently using to supply the logical voltage...
This beast weighs about 15KG and is rated at 5Amps (although I'm sure it will be fine up to at least 7A)... Ah how I love vintage electronics - it really is something different when you flip the switch and hear that distinctive transformer brrr...
The only thing keeping me from switching the supplies around and trying to see how much current I can pump through the FET is that the transformer-based supply doesn't have current limiting (other than the fuses )... Meaning than I really can't use the coax cable for testing as I did up until now because of its ultra-low resistance.
I'll put this test on the back burner for now (and probably try it later on with a car battery or something as the source).
As per the heatsink/FET insulation - I'll be getting the fittings and the insulating material come Monday I'll then be able to use regular old steel bolts and nuts to tighten it since I wasn't able to find plastic ones anywhere... Go figure The only plastic ones I managed to find were for toilet fastening
What remains now is for me to complete the heatsink mounting and print out a PCB mock-up so that I can verify all the components' dimensions - whether everything lines up okay so that I can go ahead and start making the PCB...
Do you have any experience in this field - because I'm basically thinking of printing it out on a sheet of paper and putting the components on top to see if the legs line up... Any advice would be helpful
Thanks in advance!
