Jeff Engel
The premise:
When sunlight enters the space through a window or skylight, it brings
not only light energy but also heat energy. Except in cold climates,
this solar heat gain from daylight can be a burden on the building
cooling system, and sunlight must be carefully controlled to avoid this.
But with good design, the daylight is not only a good source of light
but the most efficient. The number of lumens per watt (efficacy) of
daylight is twice that of a fluorescent lamp and ten times that of an
incandescent lamp. Properly designed daylighting strategies can both
reduce electric energy demand for lighting and minimize loads on the
cooling equipment.
Our subject: What material or method will pass or reflect most light
and reflect or absorb most heat? Anything more practical to be done
with the waste heat? Are those efficacy claims above valid? Is this
more interesting than LED holiday lights?
cooling equipment.
