Is there a small IC that can be used to measure temperature without contact? thanks, William
W William Wuister Oct 24, 2003 #1 Is there a small IC that can be used to measure temperature without contact? thanks, William
J JW Oct 24, 2003 #2 Is there a small IC that can be used to measure temperature without contact? Click to expand... How about: http://www.dalsemi.com/quick_view2.cfm?qv_pk=2737
L Lewin A.R.W. Edwards Oct 24, 2003 #3 Is there a small IC that can be used to measure temperature without contact? Click to expand... Erm...? If you are not in contact with the item being measured, then by definition you are measuring air temperature, not object temperature. It is possible to _infer_ an object's temperature from its electromagnetic emissions, but that is not the same thing
