mike
there is no thermal mass in this heater.....it is
mica-thermic
You probably shoulda been more accurate with your initial
"radiator" description.
Garbage in >>> garbage out...
mica-thermic
SCR dimmers use PWM.
I rather like the idea of wiring two heaters in series. This will reduce the
total output to half of what it was, but it will be better spread around the
room, which might be a net improvement.
Robert Macy said:The variable inductor is great for controlling resistive loads
especially in the 1kW to 10kW ranges. ...you can actually make your
own if you want.
Is this called a "Variac"?
Phil said:** It a HEATER - you fucking IMBECILE.
Phil Allison wrote:
Do you eat with that same mouth?
Admittedly, if the heating element is Nichrome, it
doesn't have much of a temperature coefficient.
Phil said:"Jeffrey D Angus"
**Do you always REMOVE the context entirely when posting
great lumps of BULLSHIT like this ??
** No fooling ??????????????
Now tell that BULLSHITTING TROLL Macy too.
An leave the FUCKING CONTEXT visible.
Idiot.
... Phil
I have one of those 1500 watt radiator style portable
electric heaters. Love it
However, rather than the built in thermostat turning
the unit OFF?ON every 15 min's or so, I was thinking
it would be more efficient to use an SCR dimmer control
to vary the amt or power it gets?
Does anyone know of an SCR control hefty enough to
handle this kind of resistive heating load??
Ok, Do you eat with that same mouth Phil?
I see they finally fixed it so that it works reliably now.
Any response gets a torrent of abuse ...
** Go get totally fucked
- you pathetic pedant & self appointed net cop TWAT.
