Hello, could someone tell me why the Volt, Amp, Watt, KW meter ( bayite AC 80-260V 20A BAYITE-PZEM-021) not show correct readings, (top right area).
---Forgot to say that meter has been tested on a heat gun and 150w lamp, and the meter shows correct readings---.
It worked at one time showing correct readings, 1300w, 11amps ect.
Now it reads 400w, 3amps ect.
the only thing I changed is coil ohms, it was around 19 ohms, in parallel around 9 ohms each coil. 1500w
I shortened coils to 16.4 ohms, in parallel around 8.2 ohms each coil. 1800w
It seems to be heating about .5 hrs sooner with the wattage increase.
It is PID controlled ( MYPIN Digital TD4-SNR PID ) I think the PID is working fine, takes about 1-1.25 hrs to heat
1 quart aluminum, ramps up steady and even, then smooth out at around 1200f and then about .5 hrs to reach 1400f.
Let me know what you think, good, bad or ugly.
Im sure not an electronic tech, but do the best I can with this old brain.
Thanks All,
THE METER ISSUE ASIDE:
If I changed over to a 50 amp SSR, could I easily convert to 220v, 25 amp.?
Thanks All,
