Schematic for 0-2 Amps voltage regulated output
Mickey
Does anyone have schematic for Output that is regulated with voltage (small
up to 2 V) and
otput is 0 - 2 Amps according to the input voltage?
Mickey
Robert Monsen
up to 2 V) and
Mickey
So you need a current source that goes from 0 to 2 amps, and is
controlled by an input voltage of 0 to 2 volts, right?
The typical way to do this is with an opamp. The current through a
transistor is measured using a resistor, and that measurement is fed
back to control the output.
If you measure the output using a 1 ohm resistor, then the current
through it has a 1 to 1 relation with the voltage across it. So, 0A to
2A will create a voltage of 0V to 2V across the resistor.
If you get an opamp, you can use it to control the output given the input.
Now, it sounds like you want to have a ground referenced current source,
meaning that your load will be between the source and ground. To do
that, you need some way to measure the current coming out of the
transistor (which is at some higher voltage) and compare that to your 0
to 2 volt control voltage (which is referenced to ground). Thus, you
need a way to 'level shift' the control voltage appropriately.
Thankfully, an opamp can do this for you.
Here is a schematic: (please view with a fixed-space font. Othewise, the
lines don't line up)
Vin=10V
o---o------------------o----------o------.
| | 100k | | | | 1 ohm
| | | | | | 0.1%
| 100k | | |
| ___ | .----)------o
| .-|___|--)--. | | |
| 100k | | | | |\| |
CTRL | ___ | |\| | '--|-\ |<
---)--|___|--o------|-\ | | >---| PNP
0-2V | | >-o-----|+/ |\ up to 2W
o----------------|+/ |/| |
.-. | | '----------o Out 0-2A
| | 100k | |
o----o------------------o----------o-----------------o Out GND
GND
(created by AACircuit v1.28.5 beta 02/06/05 www.tech-chat.de)
For this to work, the opamps will need to be 'rail-to-rail' input and
output opamps. You can get these in ICs that contain two (dual packages).
The first opamp takes your 0-2V input, and maps it to 20-18V. The second
opamp takes that, and tries to make the voltage across the resistor
equal to it by controlling the voltage on the PNP transistor's base.
The voltage 'compliance' is defined as the voltage range the thing can
produce. This will produce a voltage output between 0 and perhaps 7.8V.
If you need more voltage, you can increase the Vin to something larger.
It'll always have a voltage drop of about 2.2V at full current.
Also, there is no limit on the current at 2A. Thus, your voltage source
should limit the current it'll supply to 2A.
Regards,
Robert Monsen
"Your Highness, I have no need of this hypothesis."
- Pierre Laplace (1749-1827), to Napoleon,
on why his works on celestial mechanics make no mention of God.
Robert Monsen
Vin=10V
| | 100k | | | | 1 ohm
| | | | | | 0.1%
| 100k | | |
| ___ | .----)------o
| .-|___|--)--. | | |
| 100k | | | | |\| |
| | 100k | |
GND
Correction, from 10 to 8 V. Also, make sure the 1 ohm sense resistor is
rated for at least 2.5W.
The second
Regards,
Robert Monsen
Chris
up to 2 V) and
Mickey
Hi, Mickey. The simplest way to have a voltage-controlled current
source requires that your load can be floating. Given that, you can do
the whole thing, including perfboard, with Radio Shack parts like this
(view in fixed font or M$ Notepad):
' VCC
' |Iout = 0-2A
' '------o
' VCC
' + .------o
'Vin | | -
'0-2V ___ |\| |
' o-|___|-o----o-------|+\ ___ |/
' 750 | | | >---o-|___|--| TIP120
' .-. |.1uF.--|-/ | 220 |>
' 220| | --- | |/| --- |
' '-' | | | |.01uF |
' === === | GND GND |
' GND GND '--------------------o
' 0.22 ohm | |
' 5 Watt | |
' GND
Here's the drill. The 750 and 220 ohm resistors divide down your
0-2VDC signal to about 0-0.44V (plus or minus -- use 1% resistors for
better precision). The op amp (use 1/4 of an LM324 if you're doing the
Radio Shack thing) is set up as a voltage follower with the darlington
transistor in the feedback loop. The .01uF cap is in the feedback loop
to help prevent oscillations. Your 0-0.44V signal is impressed across
the 0.22 ohm power resistor, which translates to 0-2A through the
resistor.
This should work well with assembly on a perfboard. The power
dissipation across the transistor is dependent on the power supply you
choose. The above will work with a commonly available 5VDC regulated
power supply. With a 5V supply, your transistor could dissipate as
much as 9.5 watts for a short circuit load at 2 amps, so be sure to get
the big TO-220 heat sink.
Have fun, and good luck
Chris
W
Winfield Hill
Chris wrote...
do the whole thing, including perfboard, with Radio Shack parts like
this (view in fixed font or M$ Notepad):
' VCC
' |Iout = 0-2A
' '------o
' VCC
' + .------o
' Vin | | -
' 0-2V ___ |\| |
' 0.22 ohm | |
' 5 Watt | |
' GND
resistor.
get the big TO-220 heat sink.
Fun with oscillation Mickey may well have with the 10nF capacitive
load on the opamp, and good luck he'll need fixing it! But luck is
here - I've fixed the cap connection in the drawing below. :>)
' + VCC
' | Iout = 0-2A
' '------o
' VCC
' + .------o
' Vin | | -
' 0-2V ___ |\| |
' 750 | | | >--o--|___|--| TIP120
' '-' | | === | .01uF |
' | === | GND | ___ |
' | GND '--------o--|___|----o
' | 4.7k |
' | 0.22 ohm | |
' | 5 Watt | |
' |______________________________|
' GND
I've also shown the mandatory 4-terminal Kelvin connection that
should be used with low-value resistors at high currents.
Chris
Winfield said:
Chris wrote...
' + VCC
' | Iout = 0-2A
' '------o
' VCC
' + .------o
' Vin | | -
' 0-2V ___ |\| |
' | 4.7k |
' | 0.22 ohm | |
' | 5 Watt | |
' GND
Thanks, Mr. Hill. I saved your earlier ASCII art, but couldn't find
it. While batting it out from memory, I munged it (ouch! -- not paying
enough attention, I guess).
Here's from Mr. Hill's earlier post on s.e.d.:
.. Rload=8ohm Lload
.. 12V |---------/\/\/\------88888-------.
.. 5V |
.. --- .1uF |
.. 10k |\| | |
..---/\/\/\--+------|+\ 220 C |
.. | | >--+--/\/\/\--- B _|_/
.. | .--|-/ | E /_\
.. .1uF --- | | --- 0.01uF +------'
.. | | | 10k |
.. | / 0.2 ohm
.. | \ 5W
(Zener added for inductive load)
Thanks again.
Chris
