Scanning of numbers and string in c
I am little bit confuse in the scanning of numbers and string in c programming. I wrote program to scan numbers from user
Code:
#include<stdio.h>
int main (void)
    int number;
    printf("Enter user input :");
    scanf ("%d",&number);
    if(number == 1)
        printf("Number is 1");
    else if (number == 2)
        printf("Number is 2");
    else if (number == 3)
        printf("Number is 3");
    else
        printf("Invalid Number");
    return 0;
compiler output
Enter user input :1
Number is 1
Enter user input :2
Number is 2
Enter user input :3
Number is 3
Enter user input :4
Invalid Number
This program is able to scan input numbers
After that I tried to scan string but compiler showing error message
Code:
#include<stdio.h>
int main (void)
    char name;
    scanf ("%s",&name);
    if(name == root)
        printf("Name is root");
    else if (name == marsh)
        printf("Name is marsh");
    else if (name == belly)
        printf("Name is belly");
    else
        printf("Invalid Name");
    return 0;
hello.c: In function 'main':
hello.c:10:13: error: 'root' undeclared (first use in this function)
if(name == root)
hello.c:10:13: note: each undeclared identifier is reported only once for each function it appears in
hello.c:15:19: error: 'marsh' undeclared (first use in this function)
hello.c:20:19: error: 'belly' undeclared (first use in this function)
What's wrong happening in my program. I just want scan string without using any library, How to scan string without using any library ?
You missed teh quotes.
root is not a string.
"root" is a string.
The same goes for your other strings.
btw.: for such selections the "select case" statement is much better suited than a long list of if...then...else
You do use a library, you may not conscientiously be aware of. The library I'm speaking of is the C standard library, part of which you include by the statement "#include<stdio.h>". printf() and scanf() are the library functions you use from stdio.h.
"root" is a string.
hello.c:10:10: warning: comparison between pointer and integer
if(name == "root")
hello.c:15:16: warning: comparison between pointer and integer
else if (name == "marsh")
I understand the use of switch case statement in c programming
Code:
#include <stdio.h>
int main()
  int i;
  printf(" \n Enter a number between 1 and 4 : ");
  scanf("%d",&i);
  switch (i)
     case 1:
      printf("one");
      break;
     case 2:
      printf("two");
      break;
     case 3:
      printf("three");
      break;
     case 4:
      printf("four");
      break;
     default:
      printf(" \n unrecognized number");
but again problem is string. my program suppose to do if any user enter string program will scan that string and then string will check if it doesn't match then show invalid name and if it match then display name of string
I don't want to use any other then #include<stdio.h>
if(name == "root")
AN oversight of mine: you cannot compare strings this way in C. You need to use strcmp(), but then you need to include string.h. Or you write your own string comparison routine.
Alternatively you could use a hash function to reduce the string to a number which you then can compare to another number. But this method has f+pitfalls of its own.
many compiler does not have inbuilt string.h library
Th elibrary is not built into the compiler, it is a separate file which is compiled when required.
I didn't understand how to use with my program
Like any other library routne (you already use printf(), for example)) If your develeopment environment doesn't come with the string.h library, you are forced to write your own comparison function, or borrow ot from the library of another development package.
Have a look here.
Also, in your string example you have this declaration:
char name;
name is a char, not a string. It can store only a single character, and you scan statement will go out of bounds, probably crashing your program. To define a string you declare an array of char that can store 1 more than the longest string you need to store:
char name[11];
would allow strings up to 10 characters in length.
Bob
