Ban
The worst thing is that you directly connect the 5V supply to the input of
the V/I converter. you will need a precision reference here, maybe with
3.3V, then you probably have much less noise to begin with. Also the filter
stages should have some gain, otherwise you weaken the signal and not the
noise. You could also use a cap across the feedback resistor Rf for a first
order stage. A Tschebycheff filter is *not* a good idea for audio either,
much better will be a Bessel filter with a much lower corner frequency, if
your signals are really 18kHz max.
And with your knowledge I would engage a good analog engineer for this task,
which will make the vastest improvement.
