Rob
-Concerned about running my fridge off my Xantrex 1750 modified sine
wave.
-Got my hands on an old Best 1000W pure sine wave ups (previous owner
didn't want to put out the $$ for new batteries).
- The Best needs 120v input to activate the ups.
- I put 48v worth of batts inside the Best (batts required for the Best
to run), plug the Best into the Xantrex (for the 120V requirement to
start
the UPS) , power the Xantrex from my 12v set-up (Batt/ booster cables
from car to keep 12v Xantrex powered).
The Xantrex puts out 109V Modified sine wave
The Best puts out 125V pure sine wave
I've tested this set-up with 4 car batts in the Best 1 for the
Xantrex and it seems to work (the fridge loves the Best, even better
than
the wall plug).
Whew, now my question, is there something I'm missing? I only tested the
setup for a few minuets. Will the Best just rectify the power from the
Xantrex
so that I will primarily be running off the Xantrex? If this is the
case I can go for
48V worth of cheap batts (only used to trigger he Best).
Or will I be running off the Best (and its batts) and using the Xantrex
to
run the 48V charger in the Best (which case I should buy the expensive
deep cycle batts). Thanks for any replys...Rob
wave.
start
than
the wall plug).
Xantrex
case I can go for
to
