John Sevinsky
I've always wanted radiant ceiling panel heat in our basement, but
those panels are expensive. Recently, I found a supply of used panels
for a reasonable price, so I bought one to play with. (It's a Qmark
Aztec 375W panel.) Unfortunately, it is rated for 208V, and our house
has 240V. I hooked it up, and it worked. But, the surface temperature
in the middle of the panel reached a maximum temperature of 250F, which
might be beyond the safe operating range.
So, I'm wondering how I can reduce the power supplied to these panels.
Although this won't be perfect, I thought about some diode arrangement
that would supply power to a pair of these panels in parallel for one
half of the cycle and in series for the other half. So, they would be
getting 240V half of the time and 120V half of the time. That should
average out to less than their rated capacity, but it's better than
setting them on fire.
I also thought about a more complicated circuit using triacs or
something that would let 208 out of every 240 cycles pass through.
What about a 240V light dimmer? (Each panel is 375W)
Bulky, expensive transformers aren't an option, because I'll most
likely be better off buying the correct 240V panels at non-surplus
prices.
Ideas?
John
prices.
Ideas?
John
