RS485 15 pins to rs 485 9 pins cable?
Hey guys,
For my internship I need to make a serial communication between a servodrive with a 3 row 15 pins male output. It has a RS422/485 based protocol. In previous years the servo drive was able to communicate with a rs485 converter.
The communication link was like this : PC->(Via USB)RS485 converter (9pins male connector)->Self soldered connection wire -> RS485 15pins connection point.
But unfortunatly the cable between the converter and the (15 pins) serial output is nowhere to be found! and the colleague who made this doesn't work here anymore.
I have tried to solder it many times now, but I can't manage to get it fixed.
The following pictures are from the user guide of the servodrive:
https://imagizer.imageshack.us/v2/439x529q90/673/Iki0GZ.jpg
https://imagizer.imageshack.us/v2/885x529q90/673/32nCP7.jpg
And here is the manual itself:
http://divapps.parker.com/divapps/eme/EME/Literature_List/DOKUMENTATIONEN/sbc/manSLVDN_E5_GB.pdf
edit: And here the manual for the converter:
http://www.ftdichip.com/Support/Documents/DataSheets/Modules/DS_USB-COM485-PLUS1.pdf
I hope you guys can help me out!
Welcome aboard.
Your first link shows the connections necessary for an adapter cable. I think nothing more will be required. Make sure you have all connections in place and the shield of the cable is well connected to the shield clamps of the connectors.
