Bill Degener
RPSU280A power supply for Strata DK280 phone system schematic wanted.
Block diagram or schematic would be nice.
Bill said:RPSU280A power supply for Strata DK280 phone system schematic wanted.
There are several RPSU280A power supplies on Ebay for $25 or less. I
doubt that you can buy the parts for that price.
http://stores.ebay.com/Global-Technology-Solutions_Phones_W0QQfsubZ4
msg said:If the O.P. intends to repair quantities of defective PSUs, the request
makes sense.
Firm is in my backyard geographically - $25.00 sure is not much for a
PSU of
that size and complexity; if one is fortunate to live nearby, serious
shipping costs are avoided, but if the O.P.'s posting IP is any indication,
he would need to make a trip most of the way up I-35 to get it.
Michael
Bill Degener said:Model: Toshiba Strata DK280 Telephone system.
FIXED!
Cause: Multiple power surges from storm (yea it was on a UPS with 5
computer servers).
Symptom: All power lights erratically blinking, internal circuit breakers
clattering like hell.
Fix:
Re-flowed cold solder joints, cleaned small rails of trace residue
(literally).
Replaced C014 39uf 35v cap (ESR was nuttin) with 33uf 35v (no 39uf
unfortunately) .
Replaced C017 10uf 50v (high ESR). Replaced w/ 10uf 63v).
Replaced C013 47uf 50v with same value (proud of me for that one).
Location: Main board close to daughter board near DSUB pigtail connector.
Regards:
Bill Degener
makes sense.
Firm is in my backyard geographically - $25.00 sure is not much for a PSU of
Michael
I would agree, except I was standing there (with worn out caps and all).James said:Probably had nothing to do with power surges, capacitors fail with age and
heat, solder joints crack, none of that requires external stimulus to occur.
People tend to blame all sorts of faults on power surges, but in reality
electronics are pretty resilient, it's hard to damage something with dirty
power. Lightning strikes are another story, but there's little chance of
stopping that even with the best surge protectors.
when the power restored, the power supply went schizo. Surge finished off
the one bad cap.
Bill said:I would agree, except I was standing there (with worn out caps and all).
off the one bad cap.
Yea, today God likes me.James said:I suspect what happened is there were a few dropped cycles as the UPS
changed over, and with the worn out caps the PSU dropped out and was unable
to start back up. Either way the important part is that you got it fixed.
Michael said:First of all, you should give a brand name, not just the model. If
you want to repair it, you need to start with the electrolytic
capacitors. test them for high ESR. Then look for any shorted
semiconductors.
<http://search.ebay.com/search/searc...ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1&fsoo=1>
Bill said:Besides, you know how complex, convoluted, and demented power supplies
(engineering) can be. This thing is big! With that said, there was
still poor regulation causing the caps to prematurely heat, gas and dry out.
Nope. That'll run a few devices. Telco switching supply I assume?Michael said:Have you ever serviced a 5 VDC 1000 A power supply with a three phase
input? THAT is a big power supply.
Ross said:
Bill said:Nope. That'll run a few devices. Telco switching supply I assume?
Bill said:Just sit there and relax. I'll take care of the heavy stuff.
