mook Johnson
RMS has always been described to me as the AC current level to create the
same amount or heat in a resistive load as a DC current. This as always
been with sinusoidal currents.
In this case I have narrow 50uS pulses of current at 5 amps with repetition
rates of 500uS.
If I calculate the RMS current vs. the average current there is a sizable
difference. the average current is 0.5A the RMS current(from spice
simulation) is 1.6A.
Which if the two should be used when determining the heat generated by a
power resistor.
Assume the resistor chosen can handle the instantaneous power during the
current spikes.
I'm more concerned about the heatload this will add to the heatsink.
There is a 10X difference in power between the two.
thanks
rates of 500uS.
power resistor.
current spikes.
thanks
