Hi, I'm a projectionist in a movie theater. I need to
convert our old white light incandescent sound
"exciter" lamps over to red LED.
The entire movie industry is changing over to having
the soundtracks on film based on cyan dye, instead of
the traditional silver based soundtrack. The big
difference is that the new way is cheaper for the
studios to make. Another big difference is that almost
every movie projector in the world will need the new
red LED readers. Most have already changed over.
The soundtrack runs along one side of the film, and the
sound information is a tranparent wavy stripe which
runs down the middle of the track. The old style
soundtracks are opaque black, and the new tracks are
semi-transparent cyan blue. There is an "exciter" lamp
on one side of the film which shines through a barrel
with lenses in it, which only lets a slit of light hit
the film. On the other side of the film is a solar cell
which picks up the light information.
We have a movie starting Thursday which is our first
cyan film. I need to rig up a red LED light source
ASAP. I saw instructions on how to do this on
www.film-tech.com (search using word "homebrew"), but I
need more info. I need your help in choosing a proper
resistor for the LED.
I ordered and received 2 Luxeon Star red LEDs. Here are
their specs:
Part # LXHL-MD1D
Max Current - 350ma (300ma or under may be preferable
so I won't have to add a heat sink)
Max Voltage - 3.5vdc
Color - Red
Wavelength - 625 NM
Light Dispersal - LAMBERTIAN
Typical Flux (Lumens) - 44
The incandescent exciter lamp it is replacing is rated
at 9v 4a 36w.
I've checked the power going to the light, and it is
only 7.5dc. That's OK because most film technicians set
the power lower on exciter lamps to make them last
longer. That's what I've heard, anyway. That power
supply is adjustable, but I'd prefer to leave it at
7.5v so I can still put in the old lamps whenever I
need them. The power supply is rated at 5-10vdc and 5a.
So, what kind of resistor would I use to get this LED
to work? I wouldn't want to burn it out or run it too
dim either. I've been wracking my brain trying to
figure this out, and I'm not having much luck so far.
Not sure which formulas in Ohm's Law to use.
Thank you, Mitch
spamsuckawell-wornhat at yeahwhoo dott caum
Take off the well-wornhat to respond.
their specs:
Part # LXHL-MD1D
Color - Red
Wavelength - 625 NM
at 9v 4a 36w.
Thank you, Mitch
