fcassia@gmail.com
Hi there,
Maybe can someone could voice some ideas on the best path for this:
I have not one or two but 8 emergency lights, each having an internal lead-gel 6v battery, and two fluorescent tubes. The fixture plugs into 220v AC and when power goes out, the batt kicks in and lights the tubes, simple huh?;-)
My main goal would be keeping the case, the battery, and as much of the circuitry as possible, but instead of feeding fluorescent tubes, replace thosewith LED strips.
I have disassembled the unit and found that the circuit board is just one, that integrates all functions, battery charger, switching from AC to battery, and doing the tubes startup.
I've also measured the voltage of the wires leading to the batteries, and while the battery is 6V, I get 10 volts of charging voltage when the unit isplugged into AC -I guess this is normal-.
The tubes are a pair of 30-cm (11.8 inches) wide, labeled F8T5/D
Now, I know nothing about tubes, except that normal tubes come with a ballast and 'starter'. On this circuit board I see no 'starter' but there's indeed a small transformer, although I'm not sure if this is related to the conversion from battery DC to AC or as a step down to turn the 220vAC into the10V used for charging.
What would be the best route to do this conversion?.
I thought that ideally, I'd keep the circuit board unmodified, and just addany additional components needed to turn whatever voltage the unit feeds to the tubes, into the 12V DC expected by LED strips...
Now, anyone has more information on what voltage gets into these "F8T5/D" tubes?
and would the 'starter' effect used by fluorescent tubes fry any circuitry I add at the end of the wires before the tubes, to turn it into 12VDC ?
here, it only says
http://1000bulbs.com/product/1053/F-08T5D.html
"This F8T5 linear fluorescent lamp operates at 8 watts. It has a color temperature of 6500K, a CRI of 75, and an average life of 7,500 hours. "
....but no words about voltage
yet over here
it reads:
http://genet.gelighting.com/LightPr...th=LEDs_Replacement Lamps_Directional_MR_GU10
"Voltage
57.0
Open Circuit Voltage (rapid start) (MAX)
190.0 V
Open Circuit Voltage (after preheating) Max @ Temperature
210.0 @ 10.0 V
Open Circuit Voltage (rapid start) Min @ Temperature
So basically I'd need an IC that can turn anything from 210v to 57v into 12VDC ?
Let me know if my reasoning so far is OK or flawed, because I've never worked with fluorescent lights before and there's too many unknowns in my drawing board.
Thanks in advance for reading and any leads...
FC
here, it only says
yet over here
it reads:
"Voltage
57.0
190.0 V
210.0 @ 10.0 V
FC
