Replace variable capacitor with varicap
just like michael1978, i am also interested in learning how to replace varco with varicap.
perhaps this is a good and successful example of replacing the variable capasitor with diode varactor/varicap
http://theradioboard.com/rb/viewtopic.php?t=6327
http://x01a4.net/dirc7/elec/am-fm-radio.htm
this video "TheAstro30" that managed to change 2 gang variable capacitor with varicap from this schematic
http://www.bowdenshobbycircuits.info/radio.htm
thanks a lot
I see a few problems with the LM386:
wow..thank you, i will try your tips
thanks a lot
this is a good article too "Replacing polyvaricon tuning for varactor tuning"
http://golddredgervideo.com/kc0wox/bitx20amods/varactormod.htm
youtube:
another good example of the varicap circuit and its explanation
https://electronics.stackexchange.c...-to-properly-connect-and-drive-varicap-diodes
"Detail" of sounds is high frequency response. When humans are young we can hear as high as 20kHz and CD players and MP3's produce it. FM radio goes to 15kHz and sounds good. But an ordinary AM radio MUST cut the 10kHz interference beat frequency produced by adjacent stations and ordinary interference between them so its frequency response cuts frequencies above about 3kHz. A TRF radio has only a single LC tuned circuit so its frequency response is determined by the bandwidth of the tuned circuit which is affected by using a varactor to replace a mechanically variable capacitor.
Back to first circuit.
It work as is given with 500pF air variable capacitor as MW TRF receiver.
if you wish to turn it as normal regen look into modifications.
This circuit can work on smaller voltages using 2 AA batt - 3V.
