I did not see your reply till yesterday as I was all along looking at page 1 only. Today, I tried the lamp test with a 40 watt lamp, and found the lamp glowing dim and going off in seconds . On my second or third attempt ,I even saw the led lighting up. On checking ,I found 60 volts steadily dropping at a slow rate at the bigger condenser. I did not continue for long as I did not use suitable probes and I had to hold two flexible wires by hand and try to make contact with unsteady hands of a 80 plus aged . I will try a longer test by tomorrow to build up voltage , unless it needs a bulb of much higher wattage . What next , Thanks ..Uppala on May2,2017
After another couple of seconds the voltage has gone upto 104 DC . Now , I am certain with testing for a minute or more , It should go upto 170 plus.
