Hi, it's me again. Just finish tests few days ago and now its time to continue this project and gotta hand in and present on next friday. My teammate made this arrangement on the stripboard 2 days ago and he did the soldering too. Unfortunately, the transmitter circuit is no longer function
ive recheck all the connection, 100% correct and ive did the breaking of certain 'lines' too. And i did checking the frequency using oscilloscope, and my lecturer told me the WHOLE circuit is showing 50kHz (instead of 455kHz at pierce's oscillator and 38kHz at the Base of the npn). And i accidentally drop the ceramic resonator to the floor from a height of 1m, perhaps such drop spoil it? Im not sure what I should do now, ive recheck the whole circuit for more than 10 times, but still no guide line at all where is the problem. Im hoping someone, at least tell me what should i do or like telling me to check certain voltage drop of certain components.
Here's some detail I get after rechecking the circuit :
1) i check the voltage drop across the infrared LED, when the switch is on, my multimeter shows a pulsing values - around 300mV and swiftly it changes to around 1.4V and then keep repeating the changes.
2) there's no voltage drop across the 680ohm resistor when the switch is on.
I will provide any informations as requested.
The circuit is designed by KrisBlueNZ. Very grateful to him.
**** both the circuit work very well on breadboard fyi. ****
