Hello Everyone and thanks in advance for any help. I have a problem with some relays sticking on a homemade incubator. I'm not an electrical guy so my knowledge is far from advanced but this is what I have.
I have a 12vdc controller with a 10amp SP NO mechanical relay (built into the controller). I am controlling a 110vac 250 watt heat lamp. The cycle time varies but when it chilly outside it can cycle as often as every 2 to 3 minutes. It sticks in the ON position which I've read may be do to contact arc.
If contact arc is the issue I've read of a couple of fixes but wanted someone input that has knowledge of electrical circuits.
1. add a solid state relay to carry the load and use the controller to trigger it (but if cycle time is the issue wouldn't the mechanical controller still stick?)
2. place a diode between the relay and the bulb to prevent backfeed.
Also is it possible that the bulb surge when it comes on may be drawing more than 10amps.
Lastly my controller requires 12vdc for power but my source outputs 12.33vdc. Could this be causing an issue?
