Greetings.
First - I have had a few electronics classes. Enough to make me dangerous. I have shorted out numerous things in my long life.
I am adding a new grip to my tractor to operate a hydraulic valve, I am told I need a relay as the membrane switches in the handle wont handle the full valve current of about 30 amp. The part number for the John Deere OEM relay used with the grip I am getting is.
AT308380 - Relay - RELAY, 280-SAE J1744
these things are very expensive. From what I have read they are a special micro relay. However I am being told I can use a
Ulincos Auto Relay U1914 or JD1914
another one folks used is
CM6331
I don't doubt the folks have good working units, but I am very curious about the differences between the AT308380 and other standard 12V automotive relays folks are using. Can anyone help? If I goof I ruin an $80 wiring harness that has the grip switch built in.
If there is something special about this relay to work with the membrane switches is there an equivalent with the base plug wiring available?
The valve specifications are here. I am getting the 12 volt version http://www.argo-hytos.com/fileadmin/user_upload/Datasheet_RPE3-06_ha4010_EN.pdf
CM6331
